Polaroid FLM-3234B - nothing comes on. Standby Power is Present.
  • SkishyIshy
    Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
    by SkishyIshy
    Hey All,
    I have a Sony 65x900f that I purchased cheap because of a no-power issue.
    I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
    I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
    03-17-2021, 11:44 AM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • rex98
    JS47A/JS57A/JS77A NM-E531 onboard ram disable
    by rex98
    hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
    nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
    maybe you could help me how to shift these resistors to disable its onboard ram.
    this is is the presents and not presents...
    10-07-2025, 03:39 AM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • Crystaleyes
    Samsung BN44-00259A standby question
    by Crystaleyes
    Hi all.
    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
    08-11-2023, 05:15 AM
