A DVD player you should avoid...
  • japlytic
    • Oct 2005
    • 2086
    At one time, I bought a Panasonic DVD-S35 DVD player from a junkyard. I found something wrong was with the power supply, but I fixed it. The real problem was that the loader tray would not move.
    In this model (and its related conterparts), there were two motors on the loader assembly, one of them serving two functions (the transverse motor), which controlled both the tray and the optical assembly slider. Typically, loader assemblies have three motors; one each for the tray, optical assembly slider, and spindle motor.
    I think some sort of mechanical problem (which I could not find) has caused a "H-01" error (Tray loading error). Also, I saw a DVD player of the same model on eBay with the same "H-01" error.
    Should we avoid this particular model (and its related conuterparts) of DVD player?
  • Rainbow
    • Aug 2005
    • 1374
    Re: A DVD player you should avoid...
    Test the motor if it's good (disconnect from the controller and use 3V power supply) - this also tests the mechanics - maybe it just needs some grease.
    • japlytic
      • Oct 2005
      • 2086
      The motor is OK, but the mechanics for this motor to operate the tray and the optical assembly slider are somewhat complicated, even though there are no obstructions.
      • mbates14
        • May 2005
        • 169
        no, a DVD player that you should avoid is those stupid KOSS 5-disc surround models. those are the biggest POS machines i have ever seen. firmware corruption and controller failure left and right.
        • bogosort
          Sony DVD player stuck tray (DVP-SR310P)
          by bogosort
          I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
          Anyone knows why?
          Thank you....
          05-11-2024, 04:29 PM
          MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
          This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
          09-06-2024, 05:30 PM
        • kokopelli75
          Victrola multi-player - No audio
          by kokopelli75
          Hello!
          My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
          01-11-2025, 03:51 PM
        • unimatrix93
          LG BH6420P Home theather blue ray player repair
          by unimatrix93
          Hello everyone, I'm trying to troubleshoot this LG hometheater player.
          The customer forced her USB drive reversed into it's USB socket and since then the player won't work properly, only shows "Please wait" error forever on it's display.
          Now I started diagnosing the USB socket and the mainboard where it's connected.
          I found 20ohm resistance to ground on the 5V line of the USB.
          5V is missing and I found the buck converter of the USB line, TPS65252 IC.
          After measuring the pins I realized that both VIN and 3V3 is correctly present...
          12-10-2024, 10:31 AM
        • ChaosLegionnaire
          optical drive tray loading problem
          by ChaosLegionnaire
          i started using a couple of my optical drives again to perform some testing and backup but to my disappointment, they have tray loading problems. both drives wont eject the tray and when i load the tray back, it auto ejects the tray again. it seems that the laser sled assembly in the drives wont drop down fully to the correct position to release the tray and the laser sled assembly wont extend back up to the proper position to lock and load the tray so it auto ejects the tray again.
          i tried lubricating the gears in the tray loading mechanism and the tray sled rails but it didnt...
          02-26-2019, 02:07 PM
