Vizio P42HDTV10A Flickering Screen
  • bill_
    • Feb 2012
    • 7
    Hello, like many I see on here I have an LG Plasma with screen issues but no issues with sound. I have a decent background in electronics but zero experience in tv repair. So I've spent several hours reading posts, getting familiar with the components, and testing. I'm still poking around but I'd like some direction from the experts.
    Here are the part numbers for this set.
    Vizio model: P42HDTV10A
    LG Model: PDP42X32000
    6871QZH056B
    6871QYH048B
    6871QDH117A
    6871QCH077C
    6871QRH068A
    6871QLH059A
    Symptoms:
    Screen is mostly white noise with the entire screen flicking off and on at a high rate. You can see the on-screen display but it's very faint and distorted. Connecting a single results in some picture but it's highly distorted and very faint. Mostly black with image outlines in bits of color.
    I've done the basics:
    -Tested all removable and surface mount fuses. no issues.
    -Tested the output voltages on the power supply. no issues.
    -Removed all the boards, inspected the traces and caps.
    No obvious cap issues. I did notice odd something on the zsus board. There is a sticky substance like grease covering about a quarter of bottom. No obvious source.
    -Some post mentioned running the set for 10 minutes and finding "cool" boards. Well I tried that and everything was cool I used a thermal gun while running and touched everything once off. I wasn't running a single so maybe that was the issue.
    -The ysus board 'ticks' at a high rate when the set it on. I wasn't sure if that was normal. It's possible it's ticking in time with the screen flicker but my eyes and ears can't agree today.
    One of the other posts mentioned "Troubleshooting Manual 2007 VG training plasma". This was really useful but I could not do some of the tests because the p50 it's based on is too different. I couldn't find the test points it mentioned to scope. Is the a training manual for this model? I wanted to test the bias of the hybrid circuit but need to procedure. Based on what I've read I think it's the zsus that's the problem but I'm guessing.
    Can someone suggest some next steps?
    Thanks,
    -Bill
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: Vizio P42HDTV10A Flickering Screen
    I had the 50" version of this tv. The picture on mine was flashing very similar to yours, with a coresponding "ticking" noise coming from the Ysus board.
    I sent my board to Coppel's tv repair in the DFW area to have the IPM/Hybrid replaced. That fixed the tv.
    • bill_
      • Feb 2012
      • 7
      Thanks, that was my thought when I heard the ysus ticking but I wanted to be sure. I did some more digging and found some testing procedures for the IPM here:
      and here:
      http://monitor.net.ru/forum/files/ip...boards_456.pdf
      and here:
      http://blog.coppelltvrepair.com/2011...s-ipm-for.html
      The forward on (GND)-(SUS-OUT) and (SUS-OUT)-(VS) is 0.378. The reverse on (SUS-OUT)-(VS) is 0L which I believe is infinity on my meter. This is for both the ZSUS and YSUS.
      I also tried the short tests on Coppell's site and they check out too. All my tests were in circuit which is not supposed to matter. I realize these tests are not 100% but I feel like I'm missing something.
      Somewhere I saw a manual that covered a bunch of scope measurements but I lost the link. It wasn't for the same set but from what I've read all of these plasmas work the same so I thought I'd give it a shot.
      • PlainBill
        • Feb 2009
        • 7034
        You want the LG Plasma Quick Reference Alignment Handbook. It's available at Elektrotanya.
        PlainBill
        • bill_
          • Feb 2012
          • 7
          Thanks PlainBill this was exactly what I was looking for and I believe you posted the LG TV Plasma Training Manual in another thread which was very helpful for understanding the big picture.
          I took some measurements and now I'm thinking I have a power issue on the ysus and not a ipm issue.
          Here is what I found
          Code:
          panel (measured)
          Va  60  (60.0)
          Vs  184  (184.7)
          Vsc 120  (120)
          Vy  -200 (242-260 unstable)
          Vzb 100  (100)
          5v     (5.09)
          It appears the Vy is the problem and the block diagram in the training manual shows this voltage is independent from the ipm. I've done some short circuit and cap testing in-circuit and didn't find anything. This was all on the main ysus board and not the VSC Adj and -VY Adj risers.
          Is it time to start pulling off components? Or is there something I should look at first? I was thinking about puling off the -VY Adj board but I wasn't sure how common it was for that to break.
          Thanks,
          -Bill
          • awyatt2
            • Feb 2012
            • 407
            • america
            just fixed a vizio p42hd10a that was flickering, quick inspection found the usual power board cap problem. well that blew a couple of hrs later. retraced steps and looked for other faults,when i found the problem it was the inverter board caps swollen. i removed the cover to check the esr and saw them swelled, just for fun thought i would check the esr anyway, .03 put a few volts thru them and they went off scale.possibly they go high esr before swelling. mine now has 1000uf@50volts versus 470uf@35,now to see how long they hold up
            • bill_
              • Feb 2012
              • 7
              @awyatt2
              I scoped my power supply and the Va and Vs looked clean so I doubt that is the problem.
              I didn't have much time this past weekend but I did manage to trace out the supply to the -VY Adj. Both the -VY Adjust and VSC Adjust are feed by Vs. I attempted to remove the board but apparently my desoldering skills suck. The best I could do was turn the solder to a soft putty which was not good enough to suck it off. Even with my iron at its hottest, 900F, I was only burning the PCB. I've heard some people mention using chipquik to lower the melting point. Maybe I'll try that.
              Another option is to remove the ysus and power it on the bench so I can trace the contacts on the bottom. I'm pretty sure the power is clean feeding the VY Adj but I can't measure it because it's on the underside. Since the Vsc is clean and both boards have the same source I don't think that's the issue. I'm thinking either the Adj board is bad or something the board is feeding is shorting out which is causing the erratic swings in the output.
              Well, I have the rest of the week to think about it.
              • bill_
                • Feb 2012
                • 7
                I finally was able to remove the VY Adjust and VSC Adjust boards. I went ahead and removed both so I could compare them. I found the key to desoldering the boards was a larger tip, 800F and flux. The two pins that go through the large copper plane are still problematic.
                I couldn't find an cap issues. I even removed c20,c25 just incase something was throwing off the in-circuit reading. I was getting an off reading from the FET (Q20). It wasn't shorted but differed from the VSC board. I removed it so I could better test it but fired it in the process. The FET is a Fairchild FQPF8N60C. Can someone recommend a supplier? Digi-key does't stock it. Mouser does but shipping is $12 for a $1.50 part seriously?
                As always, hindsight is 20/20. I really should have removed the VY resistor first so I could measure the VY without anything interfering later in the circuit.
                I read this thread
                https://www.badcaps.net/forum/showthread.php?t=16274
                but the board design differs. Mine has these markings:
                PDP DOC 128B
                REV 1.1
                Transformer is:
                0047X-F
                DK 60212C
                The only active components are:
                FQPF8N60C
                200D6 PAIC I see this is a PWM but I'm not sure if I have the correct data sheet.
                Any suggestions before I order parts? Anything else I could test? I thought about powering the board but my supply is only 5v. I could also do some testing with the ysus back in the set without these boards. I could run 185v from the set into the board but I'm reluctant. It's so small I'd need something non-conductive and stable to hold it. Also the smd on it are so tight I'm worried about shorting something.
                -Bill
                • bill_
                  • Feb 2012
                  • 7
                  It's been a while and I'm finally getting back to this project.
                  The adjust boards tested fine out of circuit so I replaced them. Next I removed the Top Y-Driver board and the VY issue disappeared. A nice stable 200v. The driver board is mostly ICs and the few caps it has look normal.
                  Should I replace this board? or is there some more digging I can do?
                  Thanks,
                  -Bill
                  • bill_
                    • Feb 2012
                    • 7
                    I just got my ysus back from coppel tv. Looks like they replaced two of the large transistors where the buffer connects. I now have picture but there is a faint rgb noise covering the entire picture.
                    Any ideas?
                    -Bill
                    • linnex
                      • Dec 2012
                      I have similar problem, I replaced the big moduler in the Y board. After replaced it seems fixed my previous problem-" no video, has sound". The image is shiown afterward. But the screen image become dimmer and "snow" dot. Is any test point that I can test out the Y board is in good voltage level, all I want is make the image back to normal.
                      • Ado02
                        Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                        by Ado02
                        We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                        The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                        12-16-2024, 02:33 PM
                      • jkruns
                        M1 A2338 screen and touchbar issues after cleaning up liquid damage
                        by jkruns
                        This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                        My patient is an A2338 Macbook Pro M1 (late 2020).
                        It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                        04-22-2024, 06:45 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • aazjo
                        A1502 screen only issues
                        by aazjo
                        I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
                        I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
                        1 PPVOUT_SO_LCDBKLT OL
                        3 I2C_BKLT_SCL 9.97M
                        4 I2C_BKLT_SDA 9.89M
                        5 PP3V3_S0_EDP_R 79.10k
                        6 SMBUS_SMC_0_S0_SCL 321k
                        7 SMBUS_SMC_0_S0_SDA 323k
                        8 EDP_BKLT_PWM ...
                        11-04-2021, 11:46 PM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
