LG 42PC1RR-ZL y sus problem
  • luiznunes
    • Sep 2011
    • 33
    I have a LG 42PC1RR-ZL. It has a problem with the picture. When I turn it on, the image is flickering and the pixels are shifting colors.
    I notice that on the Y sus board the Vy has 250V instead of 200V, the Vsc is ok, with 120V and the VS has 189V.
    After more or less 5 minutes the Vy drops to 200V and the image becames ok.
    During the last weeks the time to stabilize the image had becoming from 1 minute to 5 minutes.
    Any idea of what component is causing this?
    The Y sus is 6871QYH053B. Attached is the sticker with the voltages.
    Re: LG 42PC1RR-ZL y sus problem
    Could be bad capacitors. Providing a clear picture of the power supply and other boards will be helpful.
    • luiznunes
      • Sep 2011
      • 33
      here are the photos od the Ysus and the power board. I think that is a cap too. but how to discover it? I don't know what causes or what is the path to follow that causes this slow stabilization of the Vy voltage..
        Feel each cap. Even if slightly domed (bulged), they need to be replaced. It looks like the three caps near the gap between the two heatsinks on the left are bulged.
        • luiznunes
          • Sep 2011
          • 33
          in which board are you seeing this?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            On the power board, left side.
            A working TV? How boring!
            • luiznunes
              • Sep 2011
              • 33
              no.. it seems ok..
              • luiznunes
                • Sep 2011
                • 33
                I took it to the LG repair center, and the technician told me that he replaced the Y sus board and the TV was ok. that's why I am searching on the Y sus..
                  The problem is thermal; as the set warms up the voltage normalises.
                  Some component has become thermally sensitive, either a capacitor, an adjustment or another component on the power supply.
                  You can try adjusting the Vy control and seeing if that changes the results, but it's likely to be only a temporary fix.
                  • luiznunes
                    • Sep 2011
                    • 33
                    so, there is no fix for this?
                    by adjusting the Vy control, I will lower the Vy voltage, right? so when it stabilizes, it will bem lower the the 200V necessary, or am I wrong?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      You are right, and I would take a different approach.
                      One problem with these is it's hard to find a schematic of the power supply for a plasma TV. I've seen a few, but they are rare.
                      I'd suggest this approach. With the TV set cold, disconnect the sustains from the power supply. Turn it on and measure the Vy voltage. If it reads 250V, the problem is the power supply, and skip the next paragraph.
                      If it reads 200V, turn the TV off, reconnect the Z-sustain, turn it on and measure Vy. Turn TV off, disconnect the Z-sustain, reconnect the y-sustain, turn TV on, and again measure Vy. If the problem occurs only when the Y-sustain is connected you have a choice - you can try to locate the problem, or you can buy a replacement Y-sustain. You can use some of the suggestions below for localizing the problem.
                      The first suggestion would be to try preheating areas of the suspect board with a hair dryer to see if you can eliminate the problem. Pay attention to diodes. Trace the Vy voltage back to the regulator in the power supply.
                      PlainBill
                      • luiznunes
                        • Sep 2011
                        • 33
                        But the Vy is not generated the Ysus?
                        I think the power supply only deliveries the Vs. Or am I wrong?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          No, you are correct, I was wrong. It is generated on the Y-sustain by PS101. That makes it easy - do you want to figure out what is wrong with PS101 or just replace the entire Y-sustain?
                          PlainBill
                          • luiznunes
                            • Sep 2011
                            • 33
                            Yes, I want to know what is wrong with PS101. It is more fun to repair.
                            Thank you.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Thank you.
                              That should be easy to do. I have a dead Z-sustain which contains a similar supply and just took a close look at it. It is a 4 terminal board which contains a complete DC-DC converter. Troubleshooting is non-trivial, but should not be very difficult. I would look for problems in the feedback loop, either a thermally sensitive component of a bad solder joint.
                              PlainBill
                              • luiznunes
                                • Sep 2011
                                • 33
                                the PS101 is welded to the board or it comes out from the board from the connector?
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  It is soldered in place.
                                  PlainBill
                                  • luiznunes
                                    • Sep 2011
                                    • 33
                                    do you know any schematics of the PS101?
                                    I found this one :
                                    http://images3.hiboox.com/images/390...fa988718f8.bmp
                                      I would check C51, C52 and C54 on that board; they look to be the most stressed components, followed by the solder joints of VR6, R58, R62 and R64. C48 could also cause trouble, but that would be less likely.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        I found this one :
                                        That is similar to the one you have, but there may be significant differences, particularly in the value of resistors. I would pay particular attention to IC11 - the TL431 and the variable resistor.
                                        PlainBill
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • vabea
                                          Asus X550LD Image problem
                                          by vabea
                                          Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
                                          Thanks...
                                          04-07-2025, 08:33 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
