Sharp television 32sc26b.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I am repairing a Sharp tv 32sc26b which works briefly after power up and then
    shuts down.I have checked the FBT and it is good. Can anyone offer a fix for this problem?
    Re: Sharp television 32sc26b.
    Cold joints?
    • huzo
      HP Omen shuts down when loading OS
      by huzo
      The model is 15ec-1061nm
      Board number is DAG3EDMB8D0​
      SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
      10-29-2024, 12:05 AM
    • brav1ez
      ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
      by brav1ez
      I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
      I’ve tried:
      - CMOS reset
      - Removing the SSD/HDD
      - Reseating RAM (removing each stick individually stops boot completely)
      - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
      With...
      09-07-2025, 10:47 AM
    • advant
      by advant
      02-03-2020, 12:25 AM
    • sefoster
      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
      by sefoster
      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
      11-20-2022, 09:29 AM
    • joesmoe91
      Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
      by joesmoe91
      My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
      02-22-2024, 07:38 PM
