lg 42px5r no picture with sound
Re: lg 42px5r no picture with sound
I am grateful for all the help so far. I think it is strange that the fuse and some capacitors blew and it works with a New fuse. Could it be that the fuse blew due to the capacitor breakdown and some problems with the power occured than. But now that I have changed the capacitors the power is normal but something else (maby bufferboard) broke along the way ?Comment
Are there anyone else who have a suggestion about this?
another strange thing is I found the service manual with the exact some modelnumber but in that it says I have y-sus board "6871QYH053B" 42”HD 42X3 VER.B, but I have Y-sus board "6871QYH051P" 42X2. Does anyone have a diagram for that board?Comment
Here are the photos, note that all buffer look the same as the buffer close up photo.Comment
Here is how to test Y-SUS IPM.
http://blog.coppelltvrepair.com/2011...s-ipm-for.htmlLast edited by cmj21973; 02-21-2012, 06:31 PM.Comment
Thanks.
I have measured according to the site and I found 1 thing that might be wrong. On my IPM (not the one on the picture I have 4921QP1027Q) there is no "ERout" I have "ER_I0", "ER_LOW", "ER_HIGH", "ER_DN" and "ER_UP" I have short between "ER_I0" and "SUS_OUT" and that is of course because I have it on the board ( if "ER_I0" and "ERout" is the same?) but I have 293 ohm between "+VS" and "ER_I0" if I have black probe on "+VS" and red probe on "ER_I0" the other way around I have almost Infinite.
What to think?
Does anyone have the same card and can see if it is the same on that?Comment
This may indicate a fault with the IPM. It certainly doesn't seem right.
I happen to have a 42PX5D, but I don't know if I'll be able to remove the board (as it's not really mine.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Just a thought: if you tell me where the IPM pins that are shorted connect to on the top side, I can check those. Like a big capacitor or something.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok nice, test black probe on fuse FS152 an red probe on one of the little (What are those) FL22 or any of those sitting to the right just below the big heatsink directly over the 2 capacitors C99 and C100.
by the way, also test black probe on same fuse and red probe on ground and see what you get there.
best regardsComment
Have you had the time to test this yet? Maby anyone else has the same board and can test this.Ok nice, test black probe on fuse FS152 an red probe on one of the little (What are those) FL22 or any of those sitting to the right just below the big heatsink directly over the 2 capacitors C99 and C100.
best regards
I have board "6871QYH051P"Comment
Sorry, I won't be able to get to it for a couple of days. I should be able to test it Monday. (It's in the office.) I'll report back then... PM me if I forget (I tend to forget important things!)Ok nice, test black probe on fuse FS152 an red probe on one of the little (What are those) FL22 or any of those sitting to the right just below the big heatsink directly over the 2 capacitors C99 and C100.
best regardsPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Okay, I've got access to the TV today to fix the Y-sustain timings. Here's the read outs you requested (from a TV that works reasonably well):
Fuse to FL22: Around 7.5 meg-ohms
Fuse to GND: Around 5 meg-ohms
So it would seem your board has a problem if you are getting hundred ohm readouts.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok great then I atleast know that it is a fault, you have the same board right?Okay, I've got access to the TV today to fix the Y-sustain timings. Here's the read outs you requested (from a TV that works reasonably well):
I have some solderskills so I think I will try to change it myself, I have read the post in other threads and I belive I will be able to fix it.Comment
I think I have the same board. I had no difficulty finding the components in the places you specified.
I'll try and check the model # tomorrow.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Did you have a chance to check the board today?
You did measure with the probes the way I discribed right ( black probe on fuse) ?
best regardsComment
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
- Loading...
