Philips 42PF7320 buffer heatsink removal
  • tibimakai
    • Jan 2012
    • 3680
    I would like to attempt replacing these chips on the buffer boards(all of them) since the whole screen has pinkish lines.
    I'm a beginner in smd soldering also, but I would like to learn. I'm getting the tools needed also. I'm in the process of buying a hot air station.
    Last time I have tried removing one of the heat sinks after watching a Youtube video by twisting it, I have ripped off the heat sink with the chip together and ruined the board of course. It seems that it's glued there with thermal grease.
    So this time I would appreciate some help from the pros.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Philips 42PF7320 buffer heatsink removal
    I have removed them using a hobby knife kit. I have just pried them off, putting the blade between the chip and heatsink.
    Last time I have attempted this I listened to a guy on Youtube and I twisted off the heatsink with the chip together, ruining the whole board.
    Next step is to remove 12 chips. I'm waiting on a hot air de-soldering station that I have ordered from Amazon, the model number is Kendal 899D.
    I have purchased 15 chips for $40(!) from Ebay.
    Anybody attempted this before? I would have another question, to re-attach the heatsink I should use regular thermal compound and then use hot glue around the heatsink to hold it in place? That is what this guy is using on Youtube, but it doesn't seem right to me. I'm thinking to use thermal glue and forget about the hot glue.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • harp
      Metod for removing glued heatsink from fragile component
      by harp
      I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
      06-23-2025, 02:01 PM
    • Yanleb
      Schematic or datasheet for Plasma TV buffer chip
      by Yanleb
      I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
      So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
      Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
      05-18-2022, 01:36 PM
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
