PDS 4250 sky plasma
  • sienoki
    sienoki
    • Jan 2012
    • 314
    PDS 4250 sky plasma
    Any 1 know any info on this model plasma..some 1 selling 1 local for 40quid saying picture comes and goes..bottom less pit or worth buying..
    Re: PDS 4250 sky plasma
    Wouldn't bother. Got a 42V5 panel so only 853x480 pixels, not even standard definition!
    • baddesley
      Engineer
      • Dec 2012
      • 55
      Hi Tom/anyone.
      I've got one of these PDS 4250 plasma screens and would like to fix it if possible. It powers up OK, but doesn't pass through any video input signals, instead showing a sort of fine zig-zag coloured pattern. If I connect my PC to the PC input, that does work (though not very good). That, and the DVI input show, 'no signal' when selected without anything connected, but the others all show the strange pattern instead (with or without input) - it just fails to pass through any of the SCART or Component inputs. Any ideas? I'm an ex-TV engineer (25+ years ago!), but have no experience or knowledge of plasmas and no circuit diagram, so am at a bit of a loss as to where to start -I can upload an image later if needed. Maybe a low voltage supply missing? Any help would be much appreciated. thanks.
      • ktmmotocross
        Asus X512FF disable onboard memory pattern
        by ktmmotocross
        I have different BSODs when load. i want to disable onboard memory. have BV but dont have schema to check tab for stappings DIMM_SEL 0/1/2
        Others have pattern 101 original and 010 for ram disable, but i have pattern 010 original.
        any hint what pattern to use? may i try 101
        Asus X512F
        sn - k7n0cv07x551299
        03-10-2024, 08:25 AM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
      • ArMaaN376
        Samsung PS51E550 Plasma TV
        by ArMaaN376
        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
        Opened TV cover & observed foll
        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
        How to confirm Y -Buffer board...
        06-19-2024, 04:05 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • chazh
        LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
        by chazh
        This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
        I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
        The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
        09-01-2025, 08:56 PM
