Plasma Screen Test?
  • uberplasma
    • Oct 2011
    • 85
    Plasma Screen Test?
    Hi Everyone
    Where I live, there is no garbage pick up, everyone hauls their "stuff" to one of numerous landfills. At these landfills there are numerous Plasma Tv's, all missing the PCB's(hoarded by a guy who has no idea how to fix a burnt out light bulb), they all seem intact, connectors and screen look undamaged.
    Is there a way to test the screen with out the specific units boards? Is there some way to light up the board like with a say "generic" test circuit, there are so many and I'm sure they could be used by people who are capable of performing the screen swap.
    Any Ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Plasma Screen Test?
    Originally posted by uberplasma
    Hi Everyone
    Any Ideas?
    It can't be done for a plasma panel, it MIGHT be possible with a LCD panel.
    This training manual contains a section on how to put a specific Samsung plasma panel into self test (stand alone) mode. To do that you will have to have the buffers, sustains, and main logic board as well as the proper power supply at the right voltages, and there are about a dozen adjustments that must be done to get it working.
    With a LCD panel it appears there is an equivalent function on most tcons (although I have never seen it documented). For that you will again need the proper power supply and at a minimum a CCFL tester.
    PlainBill
    PlainBill
      If you have a variable high power signal generator capable of putting out a square wave from -200V to +200V at at least 1.5 amps, then yes - it may be possible. I'm guessing this is not standard equipment.
      Maybe it's possible to use mains voltage, wouldn't bet on it. Probably blow the panel up.
      Here someone demonstrates how 12kV can light up a panel: http://www.youtube.com/watch?v=HxNd97PIar0
      However the panel is very quickly damaged by this due to internal arcing.
      With LCDs you might not even need the CCFLs to light up. You can look carefully at most LCDs for damage to the screen; when off, certain parts look a bit darker than the rest. This won't catch all types of damage, for example on the edges it will be quite difficult to see the damage.
      • retiredcaps
        • Apr 2010
        • 9271
        Hi Everyone
        Sounds like an opportunity to place local ads offering free recycling services for electronics to your fellow citizens so they can save time, gas, etc.
        A few people do this where I live. They get free parts and the people who don't want their stuff save time, gas, and busting their backs.
        This sounds like the same guy who told you an electronics course was a waste of time?
        --- begin sig file ---
        --- end sig file ---
        • uberplasma
          • Oct 2011
          • 85
          I wonder how they test them at the factories? actually the guy who hoards the boards is a ying yang who has spawned other ying yangs one being the local repair guy,who said it was a waste of time, and he does it because he doesn't want his son to have the parts because he didn't hire his sister to sell their house back in '87 before they moved onto pine st.....
          I am advertising free pick up of DLP, LCD/LED and plasma TV's for free, got 2 already, 1 up and running and offered ying yang Sr a case of beer for the stash of parts, he said bottle of whiskey and its a deal, so I will be off to the liquer store and grab a 10$ bottle and put it in my single malt bottle - hahaha
          Thanks everyone for the input, gives me some things to think about
            http://www.youtube.com/watch?v=uq9pZ...eature=related
            4.30
            Notice the oscilloscope and the custom equipment for driving the PDP.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • alltvrepairs
              Lg TCon test pins for screen test
              by alltvrepairs
              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
              Appreciate your help....
              06-13-2025, 06:33 AM
            • Zelek11
              Panasonic Plasma screen interference on left half of screen
              by Zelek11
              My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
              This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
              10-14-2022, 04:54 PM
