Toshiba 46RV530U - No Display. Has some power...
    Re: Toshiba 46RV530U - No Display. Has some power...
    Originally posted by stejones
    what u mean by the colour code pal
    Some resistors have a colour code printed on them which encodes the value - does yours?
    • stejones
      • Apr 2012
      • 55
      • United Kingdom
      yes it does pal and i posted a pic but will post 1 again
      • stejones
        • Apr 2012
        • 55
        • United Kingdom
        all i can see on the resistor is the type that i have specified and its in red pal if that helps
        • selldoor
          Slow Learner
          • 7870
          @Tom66 - hi - it is a ceramic pot with fuse/resistor and thermal break inside.
          see the pdf linked in earlier post. I cant actually find one to buy. What could he use instead - a quickblow ceramic fuse? fusible resistor? They cant have a very high opinion of their boards if they think it is going to overheat to that extent?
          • stejones
            • Apr 2012
            • 55
            • United Kingdom
            i have tried to take a pic of the resistor if this helps
            • stejones
              • Apr 2012
              • 55
              • United Kingdom
              #26
              looking at the the pdf table Rated power by combination of Thermal fuse with mine saying RGDU5M-5E could i use a 2.8W
              • stejones
                • Apr 2012
                • 55
                • United Kingdom
                #27
                TOM66 do you have any suggestion on this for me pal is there anything else i could use
                  I can't read the resistor value but my guess is 1.8 ohms. It is a fusible resistor; the exact value should not be crucial.
                  • stejones
                    • Apr 2012
                    • 55
                    • United Kingdom
                    #29
                    i take it as a 1.8ohms pal but do u have any idear wat watts they are plz
                      "Whatever Fits"
                      A bigger power rating doesn't hurt.
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        According to the table in the pdf the 5E is 2.8 watts
                        • gica69
                          Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                          by gica69
                          I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                          Resistor shows orange range silver gold and green lines.
                          Thanks in adv...
                          07-21-2025, 09:49 PM
                          09-06-2024, 05:27 AM
                          09-06-2024, 05:59 AM
