Philips 47PFL5704D F7 No Power
  • retiredcaps
    replied
    Re: Philips 47PFL5704D F7 No Power
    There isn't one. It's been integrated into the FSQ510.
    Ahh, yes, now I remember. Too many balls in the air today.
  • PlainBill
    replied
    Originally posted by retiredcaps
    Power mosfet? It usually is a 3 pin IC that is mounted on a heatsink. Measure the resistance between pins 1-2, 1-3, and 2-3.
    PlainBill
  • retiredcaps
    replied
  • kolpro
    replied
    Ok I tested for shorts and here are the results so far.
    D101--.554
    D102---.558
    D107--.458
    D111---.460
    D301--.193
    D510--.458
    D501--.457
    D203--.164
    If I test the in opposite direction I get 0 for all D***
    R104 -- 196k ohms
    tested the Bridge and no shorts it tested good
    Please let me know if I'm missing something.
  • bbjunkie
    replied
    Check in circuit, if any shorts show up then remove and re-test to confirm.
  • kolpro
    replied
    I would check the following for potential shorted components:
    - bridge rectifier
    - power mosfet
    - all diodes in and around U101
    - R104 - see if it matches its color band
    Good call on ordering 2.
    Do I need to check these components out of the circuit or can I check them in place for the short?
    replied
    If it's the drain it's tied directly to the internal fet, so it's likely the fet died in a spectacular fashion. Causes include a power surge, high temperature, peaking drain voltage (exceeding 700V is okay once or twice... but not too many times) or a chip that was just on it's last legs (e.g. from being operated near it's limits continuously, like in a current limit mode.)
    I would expect the mains fuse to blow; check that (including the plug fuse.)
  • retiredcaps
    replied
    Originally posted by kolpro
    Yep I just check that datasheet as well does this give you a flag as to maybe why it blew and maybe if I should be checking something else as well?
    - bridge rectifier
    - power mosfet
  • kolpro
    replied
    Thanks much I just ordered the part from Mouser Electronics and once the part comes in I'll post the results. I went ahead and ordered 2 just for the heck of it only cost me $11 bucks with shipping.
  • kolpro
    replied
  • retiredcaps
    replied
    Then I begin to think what would have caused this problem and if I replace the chip will it blow again. So any help would be gladly appreciated.
    Datasheet is at
    That pin looks like the Drain from figure 3. The description says high voltage power SenseFET drain connection.
  • kolpro
    replied
    LOL.....Thanks for the fast response I googled FSQ510 but not "buy FSQ510" I should have thought of that.
    again
  • retiredcaps
    replied
    findchips.com is fast easy way to find parts as it searches all the major distributors for you.
    http://www.findchips.com/avail?part=FSQ510
  • PlainBill
    replied
    What the heck is going on here!!!! We had a bunch of threads that opened with something like "My TV dont work. how d o i fix itt?"
    Now you come along and give a great description, and provide excellent pictures. It's great.
    Sorry, you only get a silver star. If you had Googled buy FSQ510 you would have discovered Mouser Electronics in Texas has them available for $1.18, shipping will run $5, and you should have it on Saturday.
    PlainBill
  • kolpro
    started a topic Philips 47PFL5704D F7 No Power
    Hello all and thanks in advance....
    I have been on this site for a few days now researching my problem and kind of have an idea of what my problem is. Long story short I have a Philips 47PFL5704D F7 and when it's plugged up I get no power at all. I opened the back and looked for the usual suspects being the caps and all seem to be good. But I did come across a IC chip (U101) labeled FVK31 "bottom line" FSQ510. This chip has 7 legs and the side with 3 legs is blown the leg is blown off the chip, so I think maybe replacing this chip may solve my problem. Then I begin to think what would have caused this problem and if I replace the chip will it blow again. So any help would be gladly appreciated.
    I also tried to find the chip and it seems that I can order off ebay from China for really cheap but do anyone know where I can get this from closer maybe radioshack? I live in Chicago.
    Thanks again.....
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • Troystain
    Help EZP2023+ updated chip database for w25q256jveq?
    by Troystain
    Hello, anyone here have updated ezp2023+ chip database in .dat file format.
    I need to add w25q256jveq chip but I do not know what data should I type.
    I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
    The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
    11-25-2024, 12:53 AM
  • inck243
    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
    by inck243
    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
    The BIOS...
    07-25-2024, 09:17 AM
  • thxd43
    Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
    by thxd43
    Hello, first of all, excuse me, I am using the translator, English is not my native language.
    I have a Lenovo ideapad 330S - 14IKB laptop.
    The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
    02-23-2023, 08:37 PM
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
