Philips 47PFL5704D F7 No Power
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 47PFL5704D F7 No Power
    The voltage on pin 5 leads me to suspect the diode on the tertiary winding or the Vcc cap is shorted. As momaka said, this is a VERY simple circuit.
    PlainBill
      Could also be an open resistor in the charging circuit.
      • kolpro
        • Jan 2012
        • 17
        Resistor R104 was showing 194k ohms before I replaced the chip now it shows about 33. k ohms with the new chip in.
        R104 -- 196k ohms
        All the above testing was done in circuit as well.
        • PlainBill
          • Feb 2009
          • 7034
          I don't think so. 'resistor in the charging circuit' is ambiguous, there are two possible meanings. There is a high value resistor from the filtered mains voltage to pin 8. Given the reading at pin 8, that resistor is good. While it is not shown in the app note, there often is a series resistor in the tertiary winding - diode - Vcc cap circuit. If that resistor were open, the smps would start, then die as Vcc dropped below the threshold.
          PlainBill
          • kolpro
            • Jan 2012
            • 17
            Question....can I test the caps and diodes for shorts while in the circuit or should I just pull them out and test them?
            • PlainBill
              • Feb 2009
              • 7034
              You can test them in the circuit. If you get ambiguous results (a diode that shows 1K in both directions), it should be removed and tested. If you get a low resistance (less than 200 ohms) across a cap, SOMETHING is shorted and causing problems.
              PlainBill
                master hoarder
                • May 2008
                • 12175
                #27
                Check D107 and C121 out of circuit.
                D107 should show a reading only in the forward direction under diode test (i.e. red probe on anode and black probe on cathode (cathode is the side marked with a white stripe)).
                C121 should go open-circuit after holding the probes on it for a second or two.
                If those components are fine, measure the resistance between pin 5 (Vcc) and pins 1/2 (hot GND).
                • kolpro
                  • Jan 2012
                  • 17
                  #28
                  D107 is showing .452 and 0L in reverse
                  C121 has a reading for about 1 or 2 seconds then go to 0
                  The resistance between pin 5 and 1 is 15.5k
                  I blew the fuse (6.3ah 250vp) when I hooked it back up today to test for voltage I'm wondering if I can get one from radio shack?
                  Should I put these components back in?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    D107 is showing .452 and 0 in reverse
                    Is that 0 or 0L on your multimeter? It makes a big difference.
                    --- begin sig file ---
                    --- end sig file ---
                    • kolpro
                      • Jan 2012
                      • 17
                      #30
                      Sorry it goes to .0L on the meter when I test it with the diode tester on my fluke....did I test it correctly?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        Yes, but lately a lot of people haven't been reporting what they see on their multimeter because they don't know how to interpret it.
                        a) 0L on an autorange multimeter means open loop or infinitiy or out of range.
                        b) 0.0 is a unit of measure.
                        c) On manual range meters, "1" on the left hand side means the same as 0L.
                        d) Some people report "no reading" when they see "1" on the left hand side. This is easily the #1 mistake.
                        e) Some people report the quantity, but not what they are measuring (volts, ohms, etc).
                        f) Some people report 1.00 ohm, but it is really 1K ohm, because they forget their dial is set on 2K.
                        PS. Your diode is good. If you had reported 0 (zero), then it would be bad.
                        • kolpro
                          • Jan 2012
                          • 17
                          #32
                          I have an auto range meter and now I see what your saying...thanks for the tip.
                          So both seem to be good I assume....
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            on my fluke
                            Does you Fluke measure capacitance? If yes, measure C121 and see if it matches the sleeve value.
                            • kolpro
                              • Jan 2012
                              • 17
                              #34
                              This one is s Fluke 75 series 2 Multimeter as no cap tester function on it. I tested the cap with the diode tester function and got those results are they good results?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Inconclusive. For example, a 1000uF cap might only be 680uF, but test "good" on a resistance test.
                                • acedogblast
                                  by acedogblast
                                  11-02-2024, 05:13 PM
                                • DynaxSC
                                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                  by DynaxSC
                                  Hi
                                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                  Yesterday, 12:20 PM
                                • Troystain
                                  Help EZP2023+ updated chip database for w25q256jveq?
                                  by Troystain
                                  Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                  I need to add w25q256jveq chip but I do not know what data should I type.
                                  I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                  The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                  11-25-2024, 12:53 AM
                                • inck243
                                  Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                  by inck243
                                  Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                  The BIOS...
                                  07-25-2024, 09:17 AM
                                • thxd43
                                  Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                  by thxd43
                                  Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                  I have a Lenovo ideapad 330S - 14IKB laptop.
                                  The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                  02-23-2023, 08:37 PM
