Philips 50PFP5332D/37
  • Mr Bill
    • Nov 2011
    • 648
    I don't know if this should be in general electronics or here, but the question i have kinda touches both bases.
    Heres a little background:
    I got a Philips Plasma 50PFP5332D/37 tv. The power supply had several bloated caps. I re-capped the entire power board with panasonic FM & FC capacitors. Put it all back together and the tv fired right up. I played with it for 30 minutes or so then turned it off. 2 days later i go to turn it back on and i wasn't getting any display. The blue LED lights up on the front but no picture or sound. Took the back off and now a cap on the either x-sustain or y-sustain is bloated.
    So:
    Is it worthwile to recap the x and y boards for good measure or just replace the one faulty cap and see how long it lasts. I'm not to concerned with the price of the caps themselves, i'm more wanting reliability and the fact that this tv weighs almost as much as me and i'm getting tired of moving back and forth from the work bench.
    I don't think the cap that is bloated now was bloated then, but i honstly don't remember even looking at the other boards. I basically just saw the power supply and that was as far as it went.
    Thanks for any input
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Philips 50PFP5332D/37
    Originally posted by Mr Bill
    So:
    I think you answered the question yourself.
    --- standard answer below, badcaps regulars can move on to next thread ---
    https://www.badcaps.net/forum/showpo...84&postcount=3
    --- begin sig file ---
    --- end sig file ---
    • Mr Bill
      • Nov 2011
      • 648
      Thats what i figured but....Do the large caps in the x-main fail. Usually the large caps in the power supply are never replaced due to the fact they don't endure the stress the smaller ones do. I'm going to replace the little caps just unsure about the big ones (200V)
      • retiredcaps
        • Apr 2010
        • 9271
        1) Post a picture of them.
        2) Also list the manufacturer and the series so we can determine their quality.
        • Mr Bill
          • Nov 2011
          • 648
          The brand is Samwha. I'm pretty sure they are a junk brand. The 2 little ones are M series. The Large Green ones are PF series. Also the large green ones are 150uf 250V.
          • retiredcaps
            • Apr 2010
            • 9271
            Series are normally 2 letters. I see PF, PT, and RH.
            RH is their caps for ballasts. From other past badcaps threads, PF and PT are mysteries since they are not on samwha's website.
            Lacking that information, I can't tell you what a suitable replacement might be, but I'm guessing Panasonic FR
            http://search.digikey.com/us/en/prod...422-ND/2433556
            will suffice of the obviously bloated one.
            I'm guessing the large cans are just general purpose caps and there are a number of choices at digikey/mouser for 150uF 250V.
            • PlainBill
              • Feb 2009
              • 7034
              I'd just replace the one with the bulging top. I believe it is for one of the supplies generated on the board.
              I wouldn't call Samwah a 'junk brand', but they do have problems with consistent quality, certain production lots are notorious for early failures. This is unlike CapXon, which is known for consistently early failures.
              PlainBill
              • Mr Bill
                • Nov 2011
                • 648
                I replaced the cap and the tv turns on but i'm getting a buzzing over in the upper left corner area.
                When the tv is first turned on you can hear the audio for about a second or two followed by a brief flash of snow then the picture comes in. I've had the tv on last night for 4 straight hours with no problems. Turned it off then went to bed. Turned it on this morning for about an hour with no problems again.
                But the buzzing is very annoying and i just have this gut feeling something is going to or is already failing.
                I measured the dc outputs on the power supply
                VS 200-215V (206.1v)
                VA 61v-65v (63.2v)
                VG 15v (14.65v)
                d5V 5.3v (5.13v)
                5VSV 5.3v (5.16v)
                5Vstb 5.3v (5.32v)
                12Vssb 12.4v (12.25v)
                VSND_POS +17v (+17.22v)
                VSND_NEG -17 (-17.12v)
                So is there anything else to check? The panel is a Samsung S50HW-YD07
                • rayrod81
                  • Oct 2010
                  • 205
                  Loud buzzing is usually indicative of a broken plasma panel. If it is coming from the upper left corner then it is possible that the glass nipple on the panel has been broken. It is in the upper left corner of the panel in the open cylinder coming off the panel frame. If it is broken then eventually all of the gas will escape and you will not get a picture. At that point it would be too expensive to repair and will only be good for parts.
                  It is possible that a component could be failing on the Y-sustain but it would be hard to pinpoint until it actually fails. The fact that you still have a picture makes me believe that the Y-main and buffers are fine but I could be wrong.
                  • Mr Bill
                    • Nov 2011
                    • 648
                    The glass nipple is still there and as far as i can tell not broken. The buzz is definitely coming from the ribbon areas on the y-scan drive board. Im putting my ear from top to bottom of that board and i'm hearing it. It gets quieter as i move towards the center of the tv.
                    Is this one of those just run it until it fails situations?
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                      This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      09-12-2024, 02:30 PM
                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                      HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 08:10 PM
                      HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
