LG 37LC2DB (37LC2D?) sound issues
  • Andy_Bee_1
    • Jan 2012
    Hi there,
    I bought a LG 37LC2DB off a local guy knowing it had a problem with the main board, in that it could not show Analog/Digital TV through the aerial. However AUX, SCART & HDMI worked fine. He had been using the TV fine for Satellite & XBox.
    This was no problem for me as I live in an area which cannot receive TV through an aerial anyway.
    I installed the TV, plugged in the Cable box, Wii and Media Centre.
    Everything was fine, for a while....
    After about 20mins the sound started making VERY loud crackle & pop noises, then would die. Turning the TV off then on did not get the sound back, but if left for a couple of hours it would be fine again.
    A month on and this loss of sound is random, it can be after 2mins, or other times we can watch the TV all day without sound loss.
    Investigation:
    I took the back off and checked for signs of badcaps - Nothing obvious!
    I went on some TV spare parts websites, spoke to a few people and bought both mainboards and replaced them as recommended. Everything worked still, then after 15mins the sound died (but with no pop & crackle this time, just muted). Over weeks this pop & crackle before the muting has returned.
    As far as I can see it hasn't got anything to do with the other boards in the TV - inverter, LCD controller, buttons, side panel etc.
    Shall I just buy the caps for the PSU? Is this likely to be the problem? All symptoms of a bad PSU seem to degrade or kill the picture - picture is crystal clear on my TV.
    Any help gratefully appreciated :-)
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LG 37LC2DB (37LC2D?) sound issues
    Pay close attention to the picture composition that PlainBill wants and PLEASE do NOT post pictures inline or offsite. See
    https://www.badcaps.net/forum/showpo...76&postcount=2
    --- begin sig file ---
    --- end sig file ---
      This is caused by the capacitors on the 19V and/or 12V rail failing. They do not have to bulge to be failed and many Samwha capacitors that LG seems so fond of using are known to fail without bulging.
      Post a picture of the power supply - top and bottom - clear and focused around the capacitors and the power supply connectors.
      • Andy_Bee_1
        • Jan 2012
        Thank you, I shall indeed take some photos and post them (hosting on this site)
        • huggy25
          • Jan 2012
          Tom 66...... I have an LG37LC2DB television. Basically I would like to know if I could bring it to you to have a look at for me as it has a problem similar to Andy Bee 1
          where it will be ok for a while then it starts making loud crackling and pop noises and I lose the picture and it will not respond to the remote control.
          Thanks in advance.
            Thanks in advance.
            I don't really do TV repairs for people, as I don't have the time (just a student.) All I can suggest is you replace the mentioned capacitors; better yet, replace ALL of them, as they will fail eventually (Samwha are bad capacitors.)
            • jjne
              Yamaha RX V675 sound issues
              by jjne
              I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
              From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
              At first I thought it was either a speaker relay or the DSP, but I don't think...
              06-24-2025, 07:01 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • acedogblast
              Marantz SR5012 popping and other sound issues
              by acedogblast
              Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
              These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
              I have disassembled the unit and was able to take out the...
              02-15-2023, 01:40 PM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • i19
              Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
              by i19
              Hi
              I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
              Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
              I want to use an CH341A (new model with 3.3v) to flash it.
              My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
              Any tips on how to connect to it? Maybe something...
              08-20-2024, 06:50 AM
