Vizio VP 322 power issue
  • donnierichards
    • Dec 2011
    Hello everyone. First post here, I just found this site and thought I would give it a try.
    I have a Vizio vp 322 tv. It has power and will turn on the first time with picture and sound. After about 3-7 minutes, there is a click, and the picture and sound turn off. The Vizio Logo remains white. Pressing the power button turns the tv off and the Vizio Logo turns orange. Pressing the power button again will turn on picture and sound but after 10-30 seconds they both turn off. Again, the Vizio logo remains white until I turn the tv off.
    I know a little bit about nothing about tv electronics, however I am an electrician apprentice and understand basic electrical theory and trouble shooting. I down loaded the service manual for the tv and are ready to tear into this. I would greatly appreciate if someone could point me in the right direction.
    Thanks, Donnie
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Vizio VP 322 power issue
    Hi- Have you already checked on the web? There are articles which suggest that the popping off is due to bad caps on the power board but of course it may not be. To get you started have you searched the forum- chances are you may not be the first person on here to have had the problem. Even reading unrelated threads would have told you what you need to know to get the best help from the forum and illustrate what you can input that might help others in the future. You will see that clear photographs of YOUR boards are almost an essential- I have seen someone spot a cold/cracked solder joint on a picture the poster had missed. The pictures need to be added using the manage attachments and I think "plainbill" has info regarding this on all his posts.
    Anyway as its Christmas I suggest you read the post headed "Vizio VP322 no picture no sound" which will enable you to get started and show what you need to ask.
    I know you have said you are an electrician apprentice but it is useful if you can post what tools you have and if you can use them ( soldering iron , voltmeter, esr meter, oscilloscope (wow I wish)
    • mr.sky
      • Sep 2011
      • 54
      I have same unit, and previous problem.
      My unit had 2 blown capacitors on power supply board.
      • jimz61
        • Feb 2012
        Hello all. My first post. But I have been reading and learning from you all for a few months. I repaired my own Samsung plasma with bad caps. Found another like it that clicked but would not power on. No bad caps. Repaired by replacing the main board. More expensive than caps, but repaired.
        I also recently repaired a Vizio VP322. Opened it up and found obviously blown caps. Replaced with Panasonic caps. Another success and I have enjoyed the TV for a few months. My successes are all the result of the information you all have provided. Thank you!
        But... I had the opportunity to pick up another VP322 with what I thought was the same problem. I thought I would fix it and give it to my mother. Opened it up and was surprised to find no obviously blown caps. Bummer! Symptoms are: when plugged in, Vizio logo turns yellow as it should, when power button is pushed Vizio logo turns from yellow to white as it should when powered on. But there is no picture or sound. No clicks, no pops, no nothing. I have limited technical knowledge (ok, none) but I have a multimeter and have learned a bit from reading here and trying my best.
        I would appreciate any guidance you can provide. Thanks!
        • jimz61
          • Feb 2012
          Oh... And I checked the fuses on the power supply board and they all had continuity.
            Capacitors can sometimes go bad without bulging, especially the crap brands.
            • jimz61
              • Feb 2012
              Thanks Tom. Yes. That was what I was thinking. They may be bad but not showing. And I bought extras of the ones I replaced on the first TV. So I think I will change them out first and see what happens. That is certainly the cheapest first step. I will update later.
              • jimz61
                • Feb 2012
                I replaced the typically suspect caps on the power supply. No change. Since I still have the first VP322 I fixed (identical tv), I thought I would open that one back up and swap boards until I found the cure. I thought I would start with the power supply, then the main input. But in doing so, am I risking damage to the good boards?
                  Power supplies are very hard to damage.
                  Unless the power supply outputs a too high voltage, the same thing applies for main boards.
                  Give it a go.
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • justice171
                    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                    by justice171
                    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                    1. Verified that all critical voltages are present:
                      • 3.3V and 5V are always present if DC is plugged.
                      • 1.8V on the BIOS chip is present.
                    2. Checked the power button functionality:
                      • When pressed, the voltage drops to 0V, indicating the button is functional.
                    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                      • Confirmed connectivity is intact, ruling out issues
                    11-26-2024, 12:39 AM
                  • claws77
                    lenovo flex 5 14itl05 power sequence issue
                    by claws77
                    hi guys, my motherboard will not start no matter what
                    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                    but rest nothing happens no sign of life.
                    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                    i have no knowledge of motherboards ....
                    10-20-2024, 02:48 PM
                  • SuperJames
                    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                    by SuperJames
                    This one's a weird one, and still unsolved despite it having gone back to Dell once.
                    Specs
                    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                    Backstory
                    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                    10-23-2023, 04:09 PM
