Samsung lcd #LN-S3241D.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I recently received a Samsung lcd modle#ln-s3241d which has a dimly lit
    screen with no picture but has good sound. When any of the buttons on the
    remote control are pressed there is no display on the screen. I do not have a
    service manual this tv.Can anyone offer a solution for this problem?
    Re: Samsung lcd #LN-S3241D.
    T-con fuse is blown. I see it often. Dead easy to repair too. You just need a new fuse, a soldering iron and some solder...
    • SEAWOLF
      • Nov 2011
      • 177
      I have examined the T-CON board, but I do not see a fuse on this board.
      The board's ID# is V320B1-Lo1-c. Can anyone say where the fuse is located
      on this board?
        Post a pic. It's tiny, usually green, and right next to the main connector. If there is no fuse, then the T-con itself is toast, but at least T-cons are pretty cheap.
        • Village Electronics
          OldPro
          • 118
          If you see it "often" does it "often" repair the TV? If so do you count those as repairs and add them to your total of items you have repaired so far?
            I've seen it once myself (and repaired it in that case) + many others on this forum (maybe 90% success rate)... and yes I need to update that list (getting unwieldy and have lost track)... and I'm an amateur. It seems to be a Samsung thing to put fuses on the T-con. I've also seen fuses on plasma TVs blow and replacing them fixes the problem immediately, maybe some kind of thermal stress blows them.
            • SEAWOLF
              • Nov 2011
              • 177
              Here is pic. of T-con board.#V320B1-L01-C.
                Need a closer and in focus pic around this area.
                • start2011
                  • Dec 2011
                  • 30
                  https://www.badcaps.net/forum/attach...1&d=1326077769
                  • SEAWOLF
                    • Nov 2011
                    • 177
                    Here is a closer focus pic around this area.
                    • seaboy
                      • Jan 2012
                      Hello! When I encountered this problem also. TV works only sound. No picture on the screen.
                      It was a blown voltage of the T-con board. Mark I have the picture. I hope I was useful information.
                      V320B1-L01-C
                        I recently received a Samsung LCD with a failed voltage regulator; it had very similar symptoms except there were some thin lines down the middle of the screen.
                        I can't see a fuse. Are there any components with designator F on the board?
                        • seaboy
                          • Jan 2012
                          This does not fuse, it is a regulator / stabilizer / voltage.
                            Yes there are two potential causes (among others); the fuse, and the regulator.
                            • SEAWOLF
                              • Nov 2011
                              • 177
                              There is a fuse #f1 which is located near CNF2 on T-CON board #V320B1-L01-C.
                                Check the fuse for continuity. Set your meter to ohms and probe both sides. You should get nearly zero ohms.
                                • SEAWOLF
                                  • Nov 2011
                                  • 177
                                  I have checked the fuse already and it is good.
                                    I would replace the T-con anyway, as it is the #1 cause of this problem.
                                    • khalidtv
                                      • france
                                      Hello, please out voltage t-con V320B1-L01-C. VGL-VREF-GVOFF-GVON-VGM-VCM-V33G-V5V-VDA-V33V.
                                      THANK YOU.
                                      • g.pol
                                        • Dec 2012
                                        • 17
                                        • greece
                                        Samsung le32r71b
                                        hi
                                        experiencing the following problem with a tv samsung LE32R71B
                                        watch the video:
                                        https://www.youtube.com/watch?v=tbB1EhkctSI
                                        check the power supply and even preventive changed all capacitors.
                                        It's okay.
                                        The model of the power supply is PSLF201501B
                                        T-con board:V320 B1 L01 C (I checked the fuse, is OK)
                                        I read, that the problem is due to the board(t-con).
                                        What percentage of valid self;
                                        Please anyone who knows anything about the problem, let us help.
                                        THANKS
                                        George from GREECE
                                        • RogerH58
                                          Samsung 46" TV LE46B530 blowing fuse
                                          by RogerH58
                                          I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                          I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                          I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                          06-10-2023, 10:27 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • triplefour
                                          Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                                          by triplefour
                                          Samsung UN55ES7003
                                          made house call.
                                          red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                                          psu has self test feature.
                                          disconnected from mainboard.
                                          determined PSU ok BL ok.
                                          suspect mainboard.
                                          disconnecting tcon has no change on operation.
                                          markings on mainboard:
                                          BN97-06531P 0151
                                          BN94-06123R
                                          found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                                          for 54$
                                          second house call:
                                          with replacement mainboard, tv turns on, has sound,...
                                          07-13-2022, 03:53 PM
                                        • Chrissygizmo
                                          Samsung ue55hu8500t tcon board fuse blowing
                                          by Chrissygizmo
                                          Hi , I've got a Samsung UE55HU8500T that has sound but no picture, I've had it open and done a quick check of voltages etc, I found that the F2 fuse on the tcon board had blown (T-CON BOARD VD_STV5565EU22BC6LV0.3 -) so I replaced it with a similar value fuse but still nothing, ten I noticed the replacement fuse had blown too . I would appreciate any help with this. Thank you in advance...
                                          04-28-2021, 11:15 PM
                                        • sinip
                                          Samsung Syncmaster T220 blown green fuse F301
                                          by sinip
                                          I replaced some capacitors in this one a long time ago, and it was working OK until it again developed a "slow start" in cold weather, especially. Once it started, all would be well.
                                          So, while it was trying to start, I've heard something getting fried inside, and after opening it, I found 4A green fuse F301 blown. Now, I'm measuring short across the C301 capacitor (1000uF/35V, it is good itself, of course).
                                          MOSFETs in the inverter are STM8139 (U302 and U303) and have no visual sign of being burnt. I don't see anything else burnt, either.
                                          Now, I downloaded...
                                          05-21-2023, 02:30 PM
