LC320SLX Power Issue
  • bullgod2kb
    • Dec 2011
    • 6
    Hey everyone,
    I am electronics technician at a college in upstate ny. An Elec Tech club member, who is also part of the Student Government Association (SGA), has brought in a Slyvania LC320SLX tv that belongs to the SGA that does not power up. I suspect that it is the power supply but I want to show the students a good way to trouble shoot the issue to determine the problem. I was hoping to see some bloated caps, but I do not see any visually damaged caps.
    The symptoms the TV has is when you push power, you get no lights or any screen activity. I read on this forum that if you unplug the inverter board, you should get a green led. I attempted that and nothing happened. Where should I attempt to take voltage levels from? Should I just go off the output leg of the voltage regulators?? Is there a was to test the mostfets while they are till in the board?
    Any insight would be greatly appreciated.
  • cmj21973
    • 267
    Re: LC320SLX Power Issue
    First step, find a service manual.
    http://www.scribd.com/doc/64856682/LC320SLX
    This has everything you need.
    disassemble/reassemble instructions
    troubleshoot flow charts
    schematics
    parts list
    • Darko442
      • Dec 2011
      • 7
      check fuse,EMI filter,ceramic resistor,and all components in voltage input circuit of PSU,and find start up resistor for PSU and check it for open circuit.and first of all find service manual for TV.
      Good luck
      Darko442
