LC320SLX Power Issue
  • bullgod2kb
    • Dec 2011
    • 6
    Hey everyone,
    I am electronics technician at a college in upstate ny. An Elec Tech club member, who is also part of the Student Government Association (SGA), has brought in a Slyvania LC320SLX tv that belongs to the SGA that does not power up. I suspect that it is the power supply but I want to show the students a good way to trouble shoot the issue to determine the problem. I was hoping to see some bloated caps, but I do not see any visually damaged caps.
    The symptoms the TV has is when you push power, you get no lights or any screen activity. I read on this forum that if you unplug the inverter board, you should get a green led. I attempted that and nothing happened. Where should I attempt to take voltage levels from? Should I just go off the output leg of the voltage regulators?? Is there a was to test the mostfets while they are till in the board?
    Any insight would be greatly appreciated.
  • cmj21973
    • 267
    Re: LC320SLX Power Issue
    First step, find a service manual.
    http://www.scribd.com/doc/64856682/LC320SLX
    This has everything you need.
    disassemble/reassemble instructions
    troubleshoot flow charts
    schematics
    parts list
    • Darko442
      • Dec 2011
      • 7
      check fuse,EMI filter,ceramic resistor,and all components in voltage input circuit of PSU,and find start up resistor for PSU and check it for open circuit.and first of all find service manual for TV.
      Good luck
      Darko442
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • justice171
        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
        by justice171
        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
        1. Verified that all critical voltages are present:
          • 3.3V and 5V are always present if DC is plugged.
          • 1.8V on the BIOS chip is present.
        2. Checked the power button functionality:
          • When pressed, the voltage drops to 0V, indicating the button is functional.
        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
          • Confirmed connectivity is intact, ruling out issues
        11-26-2024, 12:39 AM
      • claws77
        lenovo flex 5 14itl05 power sequence issue
        by claws77
        hi guys, my motherboard will not start no matter what
        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
        but rest nothing happens no sign of life.
        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
        i have no knowledge of motherboards ....
        10-20-2024, 02:48 PM
      • yaya3gmax
        Laptop Power Issue – Works on Battery, Fails on Adapter Load
        by yaya3gmax
        Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
        Symptoms:
        • Laptop works normally on a pre-charged battery.
        • Battery does not charge when adapter is connected.
        • Without battery:
          • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
          • Speakers “pop” when power cut occurs indicating harsh sutdown.
          • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
        08-21-2025, 07:16 AM
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
