JVC HD52G887 52-Inch HDILA Rear Projection TV
  • jtechie
    • Dec 2011
    • 7
    I have to say I have had NO issues with this TV! I replaced the Bulb once after 5 years.
  • repair-it
    TOSHIBA DLP 52HM95 How to reset timer module on bulb
    by repair-it
    I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
    Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
    10-11-2023, 07:18 PM
  • ezenia
    LUMIMAN Smart Bulb IC ID?
    by ezenia
    I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
    In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
    04-28-2025, 05:56 PM
  • waigy
    Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
    by waigy
    As the title.
    I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
    It looks basic enough inside with large components so I could do a full recap pretty easily.
    Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
    If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
    I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
    11-08-2024, 03:53 AM
  • gretti
    MSI Z370-A Pro, works but does not power off or reboot and USB issues
    by gretti
    I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
    The MSI BIOS included the ME firmware for the board. The size...
    10-16-2025, 02:14 AM
  • howardc64
    Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
    by howardc64
    TV was fixed just after removing Samsung's rear snap cover.
    This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
    Maybe PSU->backlight connector didn't have a good contact?...
    07-23-2025, 12:34 AM
