Snowy Vertical bands on 42MF231D/37
  • Paul678
    • Nov 2011
    • 402
    Ok, not only does this unit have "trails" and "ghosting" problems,
    but there are also snowy vertical bands that pop up, depending
    on the picture:
    They are most
    noticeable when there is a dark background. These are not
    solid lines, but rather snowy multi-colored pixels, in vertical bands.
    Would it be safe to assume that because these artifacts are vertical,
    that I may have a problem with my X-main LJ41-02758A board? I
    checked all the fuses, and the voltages coming from the main power
    supply, and all appears good. No noticably bulging caps either.
    Also, upon first turning on the TV, the menus take FOREVER to
    "fill in". Here you can see the Journey DVD menu, very slowly
    filling in, like an RC time constant (it seems like a capacitor or
    something is slowly charging.....):
    Finally the menu will fill in properly (something that is instantaneous
    on a normal TV), and if the menu is returned to later, it will fill in
    faster. I'm sure it's normal for a cold TV to be a bit slow at first,
    but this is ridiculous! Additionally, there will be a "burn in" image
    of the menu titles afterwards....a bit subtle, but definitely there.
    There is also an overall unacceptable amount of "snowiness" to the
    picture, especially with dark backgrounds, which even shows
    during the TV menu screen.
    Might I have a problem with my X-main LJ41-02758A board?
    Or is this still only a Y sustain board (LJ92-01200A)problem?
    Thanks for any advice.....
    Re: Snowy Vertical bands on 42MF231D/37
    You have a bad Z-sustain (also known as X-main) board. If when turning the TV on, things seem to slowly merge in (almost like a lava lamp, in various spots, and taking from a few seconds to several minutes) it is a problem with the pre-charge part of the Z-sustain board. If you've also got retention, the erase part is faulty, too. As both parts are faulty, it seems likely something common to it has failed.
    The Z-sustain's job is two fold. It precharges the pixels, allowing them to change quickly (this is why plasma screens can't quite reach zero brightness, although they are getting better... it's also why they can update so fast.) It also provides the erase pulse, which clears the pixels. If the erase pulse is missing, you will get image retention, because the plasma screen can actually remember the image (it has a small amount of hysteresis caused by deliberately introduced nitrogen), but unlike burn in it's a temporary thing.
    • Paul678
      • Nov 2011
      • 402
      Yes, it's very much like a lava lamp! Oozing quite slowly.....
      Ok, so do you have any idea where to look at the component
      level on this x-main board? For this particular problem?
      It's common for the Y buffer boards
      to blow out, taking a MOSFET out on the Y sustain....and I've
      replaced this shorted MOSFET and both upper and lower buffers,
      but I didn't read too much about the x-main going out as well.
      Looks like a less frequent problem.
      I've seen this as low as $24 on Ebay......think I should just
      buy one?
        buy one?
        I would just go for replacing the board. Tracing down the fault could be difficult. If you have a picture, the Y-sustain is usually okay.
        • Paul678
          • Nov 2011
          • 402
          Ok, here's an update:
          Took the x-main out, just to inspect it. All fuses good. All diodes tested good. No shorted
          caps, but didn't measure cap values or ESR. Most resistors measured good. No cracks on the board.
          Then I reinstalled it, and the main glass barrel fuse blew when I turned it on. Replaced it, but TV
          will not turn on when the x-main is hooked up now (blue light on front turns off almost immediately),
          and screen stays black except for random patches of dark grey.
          So whatever was wrong with it before, has gone completely bad now, which actually makes
          the diagnostic easier.
          Checked on Ebay:
          Lordy, these can be as low as $13, including shipping!
          http://www.ebay.com/sch/i.html?_nkw=...item4ab19198dc
          Unbelievable, but it's quite a gamble buying from people you don't know.
          But at $13, I don't have too much to lose.....
          • Scenic
            o.O
            • Sep 2007
            • 2642
            http://www.ebay.com/dsc/i.html?_nkw=...LH_TitleDesc=1
            178 instead of 111 results. No cheaper ones though.
            Searched for both model numbers + in description. You can search for multiple keywords at once by putting them into brackets, seperated by a comma (see search bar) or exclude specific words by putting a minus in front of it (without a space in between). Asterisks work as placeholders (tit* will find titanic as well as tits *cough*)
            • Paul678
              • Nov 2011
              • 402
              Thanks Scenic. Do you agree with Tom66 that the
              problems I had earlier were due to the x-main board?
              I usually like to get 2nd, 3rd, 4th opinions.....
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Sorry.. I don't have any clue about plasmas. I just like to read through all the threads
                • Paul678
                  • Nov 2011
                  • 402
                  No prob. I'm new to this stuff too.
                  Anyone else care to chime in?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    I'd agree, if the voltages are correct, it has to be the X-main. I can't see the logic main doing it.
                    PlainBill
                    • Paul678
                      • Nov 2011
                      • 402
                      Thanks for the input, Plain.
                      I'll let you all know when I get the board in.....
                        Same thing happened to me. I was repairing a 42" Samsung plasma with similiar symptoms, but it was worse, as the entire picture had turned into a blocky, slow to update mess. After performing several tests the Z-sustain gave up completely and the power supply started clicking when the Z-sustain was left plugged in, turned out a component on it had shorted (a MOSFET.) Sustain board was cheap, too, only about £15 including shipping.
                        • Paul678
                          • Nov 2011
                          • 402
                          Both "Vs" pins 10 and 11 were shorted to ground on my X-main, but I only found 2
                          transistors: Q4001 and Q4000. Neither was shorted.
                          Did your new x-main fix all the problems completely?
                          You had previously mentioned that "if you are getting trails, it means the Vsetup or
                          Vsetdn timings (on the Y-sustain) are wrong." But is it possible
                          that the X-main's missing "erase pulse" which causes the image retention, is also
                          causing the "trails" and "ghosting"? That would make logical sense.
                          I ask because it seems to me that I may have a good Y sustain board
                          at this point, because I adjusted the hell out of those two pots, and
                          I was never able to clear the picture up.
                          Thanks for your input.....
                            When I replaced the X-main in the 42" Samsung I had ghosting/trails left over. Before I did this I had almost no picture and after the picture was still watchable, it was just annoying. I adjusted the Y-sustain's Yfr timing until the retention went away, which was just a small turn one way. I suspect the reason for needing this adjustment is the X and Y boards are matched to each other at the factory.
                            Here is what the image retention looked like: https://www.badcaps.net/forum/attach...7&d=1318440015
                            • Paul678
                              • Nov 2011
                              • 402
                              Yes, the noise in your picture looks very much like
                              the two pics I posted earlier.
                              I just don't want to spend another $13 bucks, just to get
                              back to where I was before, with trails and ghosting. And
                              again, I was never able to clean up the picture adjusting
                              the Y sustain.
                              I'm getting close to just Ebaying the parts on this unit. Is it
                              worth the trouble trying to sell the plasma screen alone? I would
                              think the shipping would be difficult, it being so fragile.
                              Either that, or I'll buy a tv from someone I know who has a Samsung
                              HPR4252x/xaa, that uses the same Y sustain and buffer boards,
                              which has sound but no picture.
                              I'm hoping he'll take $10-20 for it.......
                                the Y sustain.
                                No, it's not really worth it. Try and fix it first. I'm 96.4% sure that it's the X main.
                                  LCD LED TV Service Menu Codes
                                  TCL LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  10-31-2024, 03:58 AM
                                • lowteq
                                  Partial Success Repairing Vertical White Bands on HP Z30i
                                  by lowteq
                                  Hello.
                                  I was given a HP Z30i LCD computer monitor that had several white wide vertical bands on it. I had another Z30i that was working and after a lot of swapping of components I found that the logic board, TCON board and associated ribbon cables were healthy. The problem was the ribbon cables that go from a long slender PCB across the top of the panel onto the panel itself. The problem connection was on the PCB side not the glass panel side. These ribbon cables are attached with some kind of heat set adhesive.
                                  I'm aware that this type of problem usually isn't repairable...
                                  03-27-2020, 10:49 AM
                                • mopenstein
                                  Looking for Vertical IC for RCA Chassis CTC159L CRT
                                  by mopenstein
                                  I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                                  Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                                  I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                                  09-24-2023, 10:41 AM
                                • oxi1158
                                  Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
                                  by oxi1158
                                  My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
                                  I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
                                  10-09-2020, 08:37 PM
                                • pni
                                  LG 49uf695v vertical coloured lines
                                  by pni
                                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                  11-14-2025, 03:15 AM
