Elecrograph 42" plasma TV model DTS 42 W
  • sambasilio
    • Aug 2011
    I have a 42" Electrograph plasma TV, no picture or sound. The alarm (red LED 8004) is on. The power supply is Samsung # LJ44 - 00025A.
    The standard voltages from inside the unit are:
    Va= 70; Vsc= 79; Vs= 165; Ve= 190; Vset= 220
    The measured voltages are:
    Va= 65-70; Vsc= 0; Vs= 160; Ve= 190; Vset= 160
    I appreciate your help.
  • sambasilio
    • Aug 2011
    Re: Elecrograph 42" plasma TV model DTS 42 W
    This is an update:
    When I disconnected SX, SY separately and together the condition stayed the same as above. When SL disconnected in addition to the disconnected SX and SY all voltages measured as posted inside the unit with no alarm and the green LEDs 8001, 8002 and 8003 stayed lit.
      SL = Is that an X buffer board?
      • sambasilio
        • Aug 2011
        Tom 66, thanks for your reply.
        SL connects the power board to the logic board LJ92-573A.
        • Tom41
          Honeywell Accenta G3 tamper alarm
          by Tom41
          This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
          I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
          08-31-2023, 04:00 AM
        • slybunda
          Alarm Siren issue
          by slybunda
          Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
          Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
          took siren out of the car and checked it out and pics attached seem to be the source of the issue.
          shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
          getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
          02-04-2024, 11:01 AM
        • Ady2017
          Does anyone know about 16x2 LCD screens used in alarm keypads?
          by Ady2017
          I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
          06-02-2025, 04:56 PM
        • ArMaaN376
          Samsung PS51E550 Plasma TV
          by ArMaaN376
          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
          Opened TV cover & observed foll
          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
          How to confirm Y -Buffer board...
          06-19-2024, 04:05 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
