Re: 42inch Touch Screen wont power on
All faulty would be very rare. Let's be sure you are testing them the right way. What mode do you have your multimeter on? Post a picture of it in that range.
the originals put out .192 execpt for one that was .099
is it possible they are all faulty?Leave a comment:
Yes i did before i put it in, it measured a higher voltage .264 compared to the others....
in highns sight i shouldnt have whacked it in but the guy told me there was no diffirence and since he had a double degree i believed him.
I will test all the diodes and see which one failed if one did.
If they all test fine should i try and find the same voltage / ampage diode ? and where should we go next if they all test fine?
So i can do more then 1 step.
Thanks again for your presistance
.264 both ways, or just one way? This is important. If it measures both ways, then the diode has failed.Leave a comment:
Thanks again for your presistanceLeave a comment:
2) Does it test shorted on the board?
3) Remeasure all the diodes on the board to see if any are shorted since the installation?Leave a comment:
i replaced the under preforming diode and still the same problem presists
However i checked the part i was sold and they are different,
Original was 60v 30amps
Replacement is 100V 20Amps
Guessing the problem could still be the diode ?Last edited by epicfatigue; 12-11-2011, 01:49 AM.Leave a comment:
These diodes die from temperature and sustained load. If the TV is, for example, mounted on a wall and used 24/7, the diode will succumb to the high temperatures (was it used in a business environment, for example as an advertisement display?) I wouldn't think any other component could cause the problem, but get two or three just in case. If it blows again, we'll need to look at the power supply more closely.where now?
awesome gunna go get one in a hour or so, now these generally die from overvoltage ? could i have a possible bad resistor or could it be that when they all died a power surge caused this to overvolt?
Just wondering if i should check otherthings incase it blows another?Last edited by tom66; 12-10-2011, 04:22 PM.Leave a comment:
Just wondering if i should check otherthings incase it blows another?Leave a comment:
. A faulty diode will prevent the power supply's primary side from starting properly.
checked all the diodes, they all worked they tested .194v however one tested .094 across both pins, could this be the problem?
Where should i check now?Leave a comment:
2x 1g http://cgi.ebay.co.uk/120816306484
5x 1g http://cgi.ebay.co.uk/110558339447
^ both from the UK instead of china. saves time.
edit: uhm.. i don't know where epicfatigue is from, so ignore this if it isn't UK.
I am From Australia, hence my funny hours.
I am a AMI Security Administrator for the Smart Meter Grid (so dont hate me lol)Leave a comment:
Yes, the white stuff is the thermal paste. If the paste isn't smudged, then you might not need some more paste, but I'd recommend it anyway. Here is something that will work: http://www.ebay.co.uk/itm/CPU-Therma...item3f10fcf53e
Get two or three, as one of those tubes doesn't last long.
edit: uhm.. i don't know where epicfatigue is from, so ignore this if it isn't UK.Last edited by Scenic; 12-08-2011, 04:41 PM.Leave a comment:
Get two or three, as one of those tubes doesn't last long.Leave a comment:
kool, and is it thermal paste on these? or do i need to go out and buy something special?
Also is it possible this chip we were looking for is mounted on the small heatsink?
As it is a 6 prong i will try and get the part number off it but it is labled as an ICLeave a comment:
Yes, the white stuff is thermal paste. If you replace a diode, I recommend you add some more paste (any stuff will do, you can buy it off eBay.)Last edited by tom66; 12-08-2011, 04:17 PM.Leave a comment:
the white paste on these its this just thermal paste?Leave a comment:
Yes, those readings indicate a functional diode. Now test the other diodes. No need to post more results unless you are unsure of the reading or if you are getting odd readings. We are looking for a diode which is not behaving properly.Leave a comment:
Thanks for the part number, and it's nice the manufacturer has included a marking of polarity. That indicates a diode drop should be between middle pin and each other pin, with the black terminal on the middle pin.
Let's try a test too - what reading to you get if you set your meter to diode test mode, but don't connect the probes to anything? In other words, an open circuit. I'm worried you might be confusing 0L or "1 ." for a zero.
edit: oops 1 minute too late!
open .0L closed 0 volts ? is that right shouldnt it read the voltage of the battery?
and yes lol it is .0L i am reading sorry guys
so this means it is functioning correctlyLast edited by epicfatigue; 12-08-2011, 03:13 PM.Leave a comment:
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by AJ847.63eHi All,
We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling... -
by hotglyAfter upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
Serial number: 0F00S2Y22353BF
Intel(R) ME Code Versions:
BIOS Version 12.200.143
MEI Driver...-
Channel: BIOS Requests ONLY!
by Yehuda170original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
with original broken screen i can see in device manager touch screen in human interfaces
but with the new screen it's not showing in device manager
is it lenovo blocking it? is it driver missing?
I²C is a headache -
by grimacelordHello,
I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...-
- Loading...
