My father in law just gave me his maganavox 32 lcd tv that didnt work, after a little research i found that two caps on the power supply went bad so i replaced them and now the tv works. when i went to radio shack to get the cap i needed, 1200uf 25v, they didnt have them but they did have 1000uf 25v so i got those and installed them. like i said, the tv now works, but the pictur quality is not great, colors are not great and quality alost looks like a video from the internet, it has pixalation...woould the cap that i used have anything to do with the picture quality? thanks in advance...Ryan
Magnavox 32 LCD Cap replacement
Re: Magnavox 32 LCD Cap replacement
RadioShack caps will not work; you need low ESR ones. They will probably not be causing the problem though (but they will soon, when they die.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
by howardc64Just typical LED bar failure repair but discovered a couple of things worthy of posting
PSU had a bulging cap (470uF 25V). Likely AC/DC bridge rectifier filter. Have seen a ton of 470uF bridge rectifier filter failures on a bunch of difference devices (not just TVs) Stock up on 470uF 25v 35v
2nd thing worth of note is after all the work to replace edge lit LEDs. Discovered 2 LEDs with phosphor coating differnce produing slightly differnet color temp. Result on edge lit TV = dark veritical band
Can't detect when testing the LED bar along...
by pabloroggeriHello guys. I need a replacement for UTC1316 or KA2214, in my country I can't get either of them, it is for an inexpensive radio recorder, there is no point in searching for it on e-bay or Amazon. Thank you
Assuming...7 Photos -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by DXseekerMOHello everyone!
Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...Yes0%1All backlight strips are the same quality0%1No0%0 - Loading...
