LG 60PG3000-ZA faulty, mal discharge?
Re: LG 60PG3000-ZA faulty, mal discharge?
Hi Tom66, cheers for the reply.
1. Yes replaced the main logic control board. The AV board with inputs is separate.
2. Fuses on the sustain boards are good.
3. Vs was reading 229 and Va 85. Tried to adjust them down but the Vs pot wont go any lower than 209 (fully turned) and the Va pot no lower than 70 (the Va causes the telly to shutdown anything below that).Comment
What does the ratings sticker say? 229V sounds very high for a plasma, but it is a 60", so it might be necessary for a larger screen.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I'm guessing this is a 60" from the model?
Do you have exactly the same problem as before?
Careful running it for extended periods of time with a 229V Vs, as that is too high. It could damage the boards as they are rated to 200V max.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes it's the 60".
Problem is the exact same as before.
I am with you there! lol.
Just don't really know where to go from here. Plasma's are not my forte and this unit has me bamboozled with what I want to be doing next. If it where an LCD, laptop, or games console I would have concluded by now whether or not I should continue or cut my losses, just wish there was a decisive way of knowing if the panel is bad.Comment
I can tell you as long as you have discharge in the panel and do not have any black bars, it is good.Yes it's the 60".
If you disconnect the cable from the AV board to the control board, do you get no image or the same image?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Disregard those readings previous readings. Half asleep and had meter on wrong setting. It's reading Vs 190 and Va 60, so all the same there.
Don't know if this is much help but if I disconnect the main AV board it doesn't turn itself back off again. still displays mal-discharge on screen but unit stays on.Comment
Not tonight but I can get one sorted, keep in mind this is a replacement control board and it still shows the same symptoms as before.
Got a question for you. If the AV board is bad would you get mal-discharge on the screen like in my case, purely discharge with no image present behind it? You have got me wondering what you would expect to see on screen if the AV board was completely kaput on the video end, as everything you read on discharge always blames one of the SUS boards.Comment
I'd expect either no display or corrupted display, not what you are seeing.Not tonight but I can get one sorted, keep in mind this is a replacement control board and it still shows the same symptoms as before.
I'm hoping there's a test generator on the logic board, place a jumper to enter test mode or similar.
It could also be a buffers issue... does this TV have one or two buffers?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Buffers on the right of the screen connected to Y-sus. Someone on this forum had a problem with them causing similar symptoms on an LG.
I was hoping there would be a test mode option but looks like you tried that already?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Cheers Tom. I will look into it!
Yeah, I tried putting it into test mode previously and it didn't work, nothing appeared on screen. That along with what we had been discussing really had me starting to think that you were right about the AV board/SSB board. was beginning to think it could be similar to an LCD problem solving wishful thinking probably! this is plasma! hahaha.
if your interested here is a link to the LG service manual for this T.V.
http://elektrotanya.com/lg_60pg3000.pdf/download.html
If you have a look at the repair flow charts and you can decipher the broken English! it refers to replacing the VSC board for symptoms similar to mine. An internet search was showing what they were referring to as the "VSC board" was the AV board/SSB board. but then it just gets confusing as there seems to be five buffer boards on this T.V but LG call the two connected to the Y-SUS - scan drive boards, and the bottom three are buffers. Plasma terminology is brutal! The manual has me even more confused problem solving wise.
You wouldn't have a link to the guy that had similar problems with his LG would you?Last edited by py3m4n; 02-23-2012, 07:41 AM.Comment
@Tom.
With both of the Y-SUS buffers disconnected from the Y-SUS the same symptoms are present and the Vsc and Vy test points on the Y-SUS still read as unstable like I had mentioned earlier to rayrod. What I am wondering is what should I expect from the Vsc and Vy with both the Y-SUS buffers disconnected? should I get a stable reading or an unstable one because they are not connected. If it is unstable connected or not, and the symptoms are the same, would this not rule them out as the problem? or am I over simplifying it and confusing myself? hahahahaha!!Last edited by py3m4n; 02-23-2012, 08:02 AM.Comment
by PlasMattI have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
by leggLG42PC3D -UD originally with green lamp but no display or audio.
Owner says was working, then went 'pop'.
All 5V caps bulging. replaced.
All PSU output voltages within spec but -Vy is low on YSUS.
One of three parallel fets between SUS_OUT and SUS_DN is zenering,
eventually shorts DG. Replaced all 3 - -Vy now OK.
Y scan buffer test point does not follow YSUS output below -50V
Note: This unit seems to expect YSUS output to park at -Vy in between
drive signal pattern periods. A replacement drive signal board confirms this....11-18-2021, 11:49 AM -
by mkdjHello everyone,
About me, my goal and the equipment I (don't) have:
I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
About my issue and my goal:
A friend of mine has a MacBook Air M1 A2337 that does not... -
by JarzabekPZI have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
by jorpecI have this lcd tv after i turn it on, the Qilive logo appears on the screen then 2 seconds later revert to standby, first i thought it could be the led bars, if i disconnect the backlight the tv stays on, or if i leave the led bars connected but disconnect the screen the backlight stays on, then i power the backlight though a led tester i was able to see that the tv was working, then i go to menu and lower the backlight intensity to 10(from the min 0 to max 100) then connected the backlight again and the tv worked normally but when on the menu i raise the backlight intensity when reaching 64...
- Loading...
