Re: Random Vertical Lines on Samsung LCD TV
It depends on the design of the panel, but different lines may be indicative of a T-con fault not a panel fault, as yes you are correct panel faults usually affect certain lines or the whole display.
Before you do decide to smash it, sell it to someone who can repair it.
Now, I understand the "shimming" quick fix for some issues with lcd lines. However if the problem is due to an intermittent connection, I would suspect that it would always be the same lines that are affected. Thanks for the susggestion though. I still like the fix suggested on one of the youtube videos. THe guy used a bat and tapped on top of the tv until the lines disappeard. If I had to do that, I would take a bat and take a full swing right in the middle of the panel.Leave a comment:
OK.. Thanks. So if the vertical lines changes location depending on what is being displayed, then the problem is likely upstream and most likely to be one of the logic boards (TCON, Mainboard) and not the Panel/TCP/Driver IC assembly. This is a great forum. So many helpfull people.
The main board could still be faulty, but I would say it is less likely.Leave a comment:
OK.. Thanks. So if the vertical lines changes location depending on what is being displayed, then the problem is likely upstream and most likely to be one of the logic boards (TCON, Mainboard) and not the Panel/TCP/Driver IC assembly. This is a great forum. So many helpfull people.Leave a comment:
Thanks PlainBill. I'll try opening this unit up and see. It's already broke, what is the worse that can happen other than electricute myself. I promise not to do that. I was suspecting it to be not the panel since the lines follow the overlayed OSD type display. The adventure begins. Thanks again.Leave a comment:
I'm new to these forums. I have a problem with my Samsung LCD TV. There appears vertical lines where ever there is text on the screen. See my picture attachced. I asked a local TV repairman and he said I have to replace the whole pane. Could this be fixed by replacing some kind of printed circuit board that drives the lcd panel? Thanks for all the help in advance.
PlainBillLeave a comment:
I'm new to these forums. I have a problem with my Samsung LCD TV. There appears vertical lines where ever there is text on the screen. See my picture attachced. I asked a local TV repairman and he said I have to replace the whole pane. Could this be fixed by replacing some kind of printed circuit board that drives the lcd panel? Thanks for all the help in advance.Tags: None
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by x_orange90_xI posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went... -
by polaroGreetings,
I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by AnonmisHello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly... - Loading...
