Sony Triniton will no stay on(KV-30HS420)
  • jerrylamont
    • Oct 2011
    • 6
    My Sony trinton played excellent until a couple of weeks ago. Now,when I turn it on, it immediately shuts down(in 1-2 seconds). It will not stay on at all. It is model KV-30HS420. It played well with no problems for years. I'd like to keep it. Can anyone give me an idea of whats wrong with it?
  • Village Electronics
    OldPro
    • 118
    Re: Sony Triniton will no stay on(KV-30HS420)
    How many blinks ?
    • jerrylamont
      • Oct 2011
      • 6
      Hey oldpro..
      Initially it blinked(red light) 3 times and went back off. I then retried it and this time it blinked 5 times and the tv stayed on. Now, It's back up. I've turned it on and off about 8 times now and.. it keeps coming back on.(the problem seems to have fixed itself). I'm going to let it stay on now until it goes back off. What do you think the problem is(or might have been)??? I will let you know if it goes back off and how long it stays on(I'm timing it)....
      • jerrylamont
        • Oct 2011
        • 6
        The TV is still playing continously, after 24 hours. the problem seems to have rectified itself but,,, I'd still like to know what it was in case the problem happens again....
        • PlainBill
          • Feb 2009
          • 7034
          This really sounds like bad solder joints. Likely places are around heavy parts such as the flyback, and heat sinks (horizontal output transistor, vertical deflection circuit, power supply)
          PlainBill
            OldPro
            • 118
            Hey oldpro..
            When the set is on there are no "blinks". Do not count the blinks that lead up to the power on. The only blinks that count are those that start after it fails or fails to start.
            The problem did not fix itself. It is an intermittent problem. While the set runs you can do nothing. It may continue to run forever. Once you turn it off, it may or may not turn back on. It may or may not turn back on in service mode. This model stores in a rom errors that occur. The service mode sequence is Display-5-volume up-power in less than 3 seconds. Don't use it. You can do more harm than good if you are not 100% sure of what you want to do. The diagnostic start sequence is Display-5-volume down-power. There you will find a list of the last errors in order. This is if it powers on at all.
            The power will turn out to be 2 IC's. I strongly urge you find a competent, local TV shop to do the work. This is a well known repair. If you bring the chassis to the shop most that I know will be glad to get the easy repair and only charge a very minimal amount which will be worth it to you.
            • jerrylamont
              • Oct 2011
              • 6
              thanks oldpro...
              The set has been continously running now for 4 days, I've turned it on and off without any problems... Until it happens again, not much I can do,,, thanks..
              • jerrylamont
                • Oct 2011
                • 6
                Well... It did it again. It would not stay on again, after working continously for more than 2 weeks... I cut it off and unplugged it from the power supply for about 18 hours... It's working again now(albiet, temporarly) .. but it's staying on.... Any Ideas on what part or board might be the culprit???
                • jerrylamont
                  • Oct 2011
                  • 6
                  I've discovered that the tv will stay playing when it's on.. even for days.. etc.
                  problem is, when you turn if off, it wont come back up unless you unplug it from the wall and let it sit about 24 hours.... when it's back up it will continue to play.. until you turn if off... any idea what it might be????
                  • weirdlookinguy
                    • Sep 2007
                    • 1638
                    This sounds like the famous MCZ3001DB issue.
                    Easy repair. And a good Trinitron is always worth the repair. The mid/late 2000's Trinitrons were the last good CRTs ever made.
                    • weirdlookinguy
                      • Sep 2007
                      • 1638
                      Here's my writeup of swapping the two ICs on my 34XBR960:
                      https://www.badcaps.net/forum/showpo...6&postcount=49
                      Note, I used sockets, and some of the kits for these TVs come with the two ICs and sockets. Don't use sockets! It wasn't until after the fact that Wizard pointed out that TVs have crazy thermal cycles and sockets are a bad idea. Sure enough about 8 months after the repair my TV started acting funky again with turning on. I reseated the ICs and all was good. I need to take it apart again and get rid of those sockets sometime. So, solder the ICs directly, and you'll be all good!
                      • homerging
                        • Dec 2011
                        • 24
                        Those MCZ3001 chips do not last and will need replacement again at some point. I haven't heard of others who've used sockets having thermal cycling problems. Admittedly I'm not an expert but I would be more concerned about accidentally toasting or shorting the fragile board's connections during a re-resoldering than having to reseat an IC in a socket.
                        If a socket were to be used, can anybody comment on the best socket type/method to prevent unseating due to thermal cycling? Would machined pin (rounded) or ZIF be better?
                        ZIFs without gold contacts seem to be very rare though.
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
                        • dkneyle
                          Sony KDL-46HX850 Can't upgrade/update firmware
                          by dkneyle
                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                          09-25-2024, 10:44 PM
                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 05:27 AM
                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                          09-06-2024, 05:30 AM
                          Sony VAIO SVE1413XPN Notebook E Specification for Upgrade or Repair
                          This specification for the Sony VAIO SVE1413XPN Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVE1413XPN boardview and SVE1413XPN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
