Panasonic plasma horizontal lines
    Panasonic plasma TH-42PZ70BA. Full HD 1080p 42" set.
    I fixed a Y-sustain (SC board) issue in this TV preventing power up (6 blinks - energy recovery SOS. Turned out to be a shorted MOSFET.) However to get the Y-sustain out I had to remove the buffers. After assembling it all I've now got a good picture, apart from varying width horizontal lines across the screen and even or odd fields from each block missing on some bars.
    I was able to, with a lot of coercing and careful screwdriver tapping near the connectors, to get the display mostly okay on the bottom side, but a few lines still exist... and the top side is very bad still as I haven't attempted that. I've tried some contact cleaner too, that seemed to help.
    So, is there a better way to go about this?
    I'll post pictures tomorrow if needed.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic plasma horizontal lines
    I had a similar issue when i worked on a TH-42PX7A. The y-buffers had been played with. It took me about 3 goes to figure it out. All i remember is although they appeared to be seated corectly they were not. the clue I got was the locking levers were raised ever so slightly as the ribbon had not fully gone in and seated. when i got it right you could feel them click in just that little bit further and the tabs were easier and fitted totally flush.
      Thanks for your help - using your method I was able to get the picture perfect. Thanks!
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Ihandyrepair
        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
        by Ihandyrepair
        Hi guys
        I just started fixing 4k TV few months ago. so I am still learning a lot
        I got this tv from friend complaint is ghosting or horizontal lines on image.
        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
        then it started to show the ghosting white image.
        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
        it has 3 thin small boards at the bottom of the...
        12-05-2022, 04:18 PM
      • busted&disgusted
        Panasonic Plasma TC-P50ST30 Horizontal Black Lines
        by busted&disgusted
        I have a 2011 Panasonic Plasma HD 3D Viera model notorious for the SC board failure. As per a Google for the dreaded 14 blink code I discovered from info on this forum about isolating suspect boards by disconnecting the power cables and using an ohmmeter on the power terminals and this led me to the SC board. I had it repaired by a nearby technician who replaced the shorted transistors and before I got the board back I wondered if any of the buffer boards are damaged and a YouTube showed how to test these by using the ohmmeter and removing the copper colored ribbon cables to the display and use...
        10-05-2019, 09:51 AM
      • ggil44
        Sony XBR-65X750D Horizontal lines bottom of screen
        by ggil44
        Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
        05-30-2023, 07:51 PM
      • rstrube
        ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
        by rstrube
        Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
        Hi Everyone,
        I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
        Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
        11-23-2025, 01:37 PM
