Sony Bravia LCD wont turn on, I check the fuse near the power cord but its ok, is there another fuse> TIA
Sony KLV 40V530A
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
by corrizeHello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks... -
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... -
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
from what i read online it looks to be an emmc issue…
i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
i took out the board and say an samsung 16gb emmc
i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM -
Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
Channel: Schematics and Boardviews
10-16-2024, 05:15 AM -
- Loading...
