Hp pl4260n help!
  • sdngs
    • 8
    Hp pl4260n help!
    hey guys.. my hp pl4260n plasma was working great one day and then the next i got this next day (see link). So this tv has been replaced and has been sitting in my basement with much thought of what to do with it. Until last month when my Samsung went out with a simular issue. On the Samsung i was able to replace the buffer boards and now that one is back un and running.
    http://www.youtube.com/watch?v=ES3n9F_ob6k
    So the question is: Can the HP PL4260n be fixed.?
    my thought is either the digital board or the buffer boards..
    Thoughts?
    Scott / swdoenges@yahoo.com
  • rayrod81
    • Oct 2010
    • 205
    Re: Hp pl4260n help!
    Yes it can be fixed. The problem looks at though the buffer board has gone. There is only on long buffer board on this one as it is the LG 42X3 panel. Pictures of the back of the TV will help you get more definitive answers or help in finding the problem.
    • sdngs
      • 8
      Here's a shot at the open backside of the Hp tv.. Looks as if the buffers are long the left side..
      thoughts on the best places to get repaired or replaced?
      see attached images
      • sdngs
        • 8
        Here's a couple additional pics of the buffer boards..
        any help would be helpful and if anyone knows a great place to get some of these components
        Thanks!
        • sdngs
          • 8
          bump
          • reddiesel
            • Oct 2011
            • 11
            Have you tried EBAY ?
            • sdngs
              • 8
              thoughts between either the buffer board and the YSUS main board, i've had one comment on anther board that it's NOT the YSUS board
              thanks!
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • Yanleb
                Schematic or datasheet for Plasma TV buffer chip
                by Yanleb
                I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                05-18-2022, 01:36 PM
              • legg
                LG 42PC3 buffer output doesn't follow YSUS
                by legg
                LG42PC3D -UD originally with green lamp but no display or audio.
                Owner says was working, then went 'pop'.
                All 5V caps bulging. replaced.
                All PSU output voltages within spec but -Vy is low on YSUS.
                One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                eventually shorts DG. Replaced all 3 - -Vy now OK.
                Y scan buffer test point does not follow YSUS output below -50V
                Note: This unit seems to expect YSUS output to park at -Vy in between
                drive signal pattern periods. A replacement drive signal board confirms this....
                11-18-2021, 11:49 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
