cello c1973f
  • betton
    • May 2010
    • 13
    cello c1973f
    Hi everybody and thanks for a great forum
    just a quick question.
    Ive just recapped a 19" lcd tv/dvd
    and it now works fine but the problem is now when I turn it off or into standbye
    it loses all it,s digital channels.
    I then have to retune it
    any help would be apprecated
  • raw2k5
    • May 2013
    Re: cello c1973f
    Hi mate - I know its probably too late, but to fix this problem turn the tv on, then press menu, 1, 1, 4, 7 and this will give acess to the service menu. then press down till you highlight FormatMXPDVB, then press right then ok. wait a while then switch it off then on. then re-tune and it should save for ever!
    This fixed my Cello c1973f!
    • Woodsworth
      PS3 CECHC03 60GB YLOD Troubleshooting
      by Woodsworth
      I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
      START
      Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
      03-19-2024, 07:58 AM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • BMCappelletti
      Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
      by BMCappelletti
      Hi everyone.
      Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
      Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
      Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
      02-18-2025, 12:22 PM
    • alegatorul
      Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
      by alegatorul
      hi,
      i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
      Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
      I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
      11-03-2024, 02:28 AM
    • eliemgh
      lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
      by eliemgh
      lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
      09-27-2024, 02:40 AM
