Westinghouse SK-26H735S -- No Power?
  • niccador
    • Aug 2011
    Hello.
    New user here, stumbled onto the site while trying to scour Google for my issue here...
    Was given a relatively "new" Westinghouse LCD TV by some friends, whom, after a recent lightning storm, found that the TV would no longer turn on.
    The only sign that the TV was receiving any power at all was/is that the SPDIF optical output port flashes like a spastic 2-year-old as soon as you plug it in. No response to any controls, no other lights, no sound (though I didn't try actually plugging in to the optical)....just nothing. Seemingly dead TV.
    Tried replacing the obvious power supply unit first. No change, same issue/symptoms. So, that seems to be good.
    Next piece in line is the main board.
    But, since trial and error diagnosis is a little on the expensive side, I thought I'd get a few opinions and expert guesses on the issue first.
    Re: Westinghouse SK-26H735S -- No Power?
    You just replaced the PSU? I would have thought it would have been repairable. Anyway... check the voltages on the connectors going to the main board. A picture of the connector would be helpful.
    • cadiman
      • Mar 2010
      • 397
      I have seen alot of people replace power supplies (cheaper sometimes) when they really needed a main board (more expensive and sometimes hard to find).
      storms seem to take out the main board more than the power supply.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • justice171
        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
        by justice171
        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
        1. Verified that all critical voltages are present:
          • 3.3V and 5V are always present if DC is plugged.
          • 1.8V on the BIOS chip is present.
        2. Checked the power button functionality:
          • When pressed, the voltage drops to 0V, indicating the button is functional.
        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
          • Confirmed connectivity is intact, ruling out issues
        11-26-2024, 12:39 AM
      • claws77
        lenovo flex 5 14itl05 power sequence issue
        by claws77
        hi guys, my motherboard will not start no matter what
        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
        but rest nothing happens no sign of life.
        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
        i have no knowledge of motherboards ....
        10-20-2024, 02:48 PM
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
