Samsung LN32b360 no power, no indicator
  • supratkfy
    • Jul 2011
    So my TV of 14 months just went out...its the samsung ln32b360. i don't have much experience in TV repair but i wanted to try since my TV isn't old and if its a cheap part maybe i can get it done. I have some experience to electrical repair. the TV stopped working completely after a power outage at my house. No red indicator light or anything.
    I took out the power board for the Samsung LN32b360.
    Capacitors all look ok.
    I went to check diodes with my DMM. found one of the diodes had flow in both directions, while all others checked out fine. it was ZD804 on the board. if this is the problem, can i get the diode from an electronic store or would i need to order it from digikey?
    any help would be great.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Samsung LN32b360 no power, no indicator
    Sounds like you found the problem. Here is another post with the same set to confirm.
    https://www.badcaps.net/forum/showthread.php?t=11904
    • supratkfy
      • Jul 2011
      Yea I saw that thread. Now would I need to order from digi key or can I get a diode from some store like radio shack?
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        You should be able to find the numbers on the part and order it or an equivilent on digikey. They have a great search on their site.
        • supratkfy
          • Jul 2011
          So I read 1n4740 on the diode?
          Looks like there's a few with 1n4740a so would it make a difference?
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            You should be good with those.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • EazyBone
              Samsung The Frame TV no power indicator issues diagnosing the one connect box
              by EazyBone
              I got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
              I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
              While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small...
              07-28-2024, 04:46 PM
            • mrtek
              Samsung UN43NU6950FXZA No power
              by mrtek
              Hi
              Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
              Main fuse = OK
              Back light LED = OK. Power them with aux power source
              LED output = OK 156V
              I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
              Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
              07-20-2025, 08:06 PM
