Philips 50PF7321D/37 4 Red Blinks
  • cbaird0512
    • Jul 2011
    • 3
    I have a Philips 50PF7321D/37 that gives me a 4 blink code when I try to power it on. From what I've read this could be the result of a faulty power supply, is this correct? I have removed the power supply from the TV but haven't noticed any bulging or corroded capacitors (I'm far from an expert here but I've done my fair share of research so far). If I replace the entire power supply (part number 996500033879), will I fix this problem? Thanks so much in advance for any help!
    Charlotte
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 50PF7321D/37 4 Red Blinks
    Charlotte
    It depends. The information is in the Philips Service Manual. That TV uses the EP1.1U.AA chassis, the service manual is available on Scribd. You can view it online, or download it for a fee. I checked the service manual for a slightly different chassis, and error code 4 indicates an I2C error, which never generates a blink code
    PlainBill
    • cbaird0512
      • Jul 2011
      • 3
      I believe I saw in the service manual a run down of what each number of blinks indicates. It said something like 4 blinks = +5V (??), but I'm not sure what that means.
      • Liam.25
        • Feb 2011
        • 107
        • Uk
        you have a faulty ssb.
        • cbaird0512
          • Jul 2011
          • 3
          I'm not sure what ssb is. And can I replace it myself?
          • Liam.25
            • Feb 2011
            • 107
            • Uk
            i had the same problem. ssb is small signals board below the psu. easy enough to replace.
            • PlainBill
              • Feb 2009
              • 7034
              The error codes are discussed on pages 25 and 26 of the manual I linked above. 5V supply is 6 blinks. Error code 4 generates a 3 hz flashing signal.
              PlainBill
