Mitsubishi 30" LCD tv Buzzing power supply
  • andy smethurst
    • 49
    Hello, I have this good working Mitsubishi DV300 lcd tv,except the power supply emmits an anoying humming buzz.It dose not effect the picture,and have located it as the transformer on the main power supply,that feeds the inverter board.It only takes a minuite from start up to become audiable and increases in volume till it peaks. This thing is 6 years old and would like to fix the problem, but what is it? I can't find much on this device on the net,no schematic or guide.I am greatfull for any advice and the location of any information on this "Mitsubishi Diamond Digital DV300" 30" lcd multifunction display. Thanks again.
    Regards:Andy
  • PlainBill
    • Feb 2009
    • 7034
    Re: Mitsubishi 30" LCD tv Buzzing power supply
    Regards:Andy
    It's difficult to say. My crystal ball is in the shop for it's annual recalibration and update. Since you didn't bother to include any pictures that means any suggestion is pretty much a shot in the dark.
    It sounds like it might be loose windings on the transformer, or whatever it is. You could try soaking the component (transformer?) in varnish.
    PlainBill
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
