Re: 42' plasma TV - Denver KTV-55 - Faulty power supply
Pin 4 turns regulator on or off.
voltage greater than 2volts = on
voltage less than .8 volts = off
output voltage is low regulator need capacitors on input and output to give good voltage. Yes you can use a resistor to provide dummy load in your testing setup.
PlainBill was asking you to lift pin 1 and measure amps going in to the regulator from the board.
Thanks Plainbill
I unsoldered the voltage regulator an put it on a PCB like (I don't know how its called in english : The blank ones used in labs where you can put components and wires without soldering).
So I was free to perform all tests. I can't check the temperature because power is on during 1 second then the relays turn it off. So there is not enough time for this component to heat.
Here are the results, during the second when the power is on :
pin 1 (Vin - Dc input) : 20.3 V - 38 mA
pin 2 (Vout - Dc output) : 9.3 V (instead of 15 V) - 33 mA
pin 3 : Ground
pin 4 (On - Off control) : 6.3 V - 0 mA
If this voltage regulator,is driven by a current, this is obvious that it can't work with 0 mA on pin 4. What sounds weird to me is that there is 9.3 V and 33 mA on pin 2, it should be 0.
This component is still out of the board. Is it possible to put a dummy resistor instead of pin 4 to check if there's a significant current which would mean that pin 4 is open ?
Are they common failures on those kind of PSU that prevent voltage regulators to be set to "On".
Thanks again.Leave a comment:
Thanks a lot. this website seems to be very interesting.
I found a KIA78R15PI (voltage regulator) that gives me 10 V (Vout controled with a scopemeter) instead of 15 V, wich may explain that the NCP1653 controler doesn't drive correctly the FETs.
Does that means that the voltage regulator is bad ? (That sounds weird to me, I thought that a bad voltage regulator should give the same voltage as Vin if shorted, or nothing is open but not another regulated voltage)
Does that mean that it is overloaded ? How can I chack that ?
Thank you.
If it radiates heat and leaves a blister on your thumb, it's overheating.
PlainBillLeave a comment:
Thank you.Leave a comment:
http://blog.coppelltvrepair.com/Leave a comment:
Hi, I'm back with another problem ;-) I hope that someone will help...
I bought 5 TVs from a guy who thought that they were LCDs (I know a bit more about LCDs). When I was in front of the TV's, they were obviously plasma TVs. They were cheap and my aim is to learn, so I bought them. But now I need your help to fix them !
The PSU is a Samsung one : LJ44-00133 A (I seached a lot and can't find the schematics, if someone can help ;-) ).
The problem :
When I plug the plasma, the led panel is red (which seems to be ok)
When I turn on the plasma the led turns to green, I hear a relay turn on and off during a second but the panel stay green (that is strange because it usualy blinks red).
No way to turn it off and on again using the button : I have to unplug and replug the TV to hear the relay again by pressing the button.
-Fuses are OK.
-All eletrolityc caps are OK (unsoldered and tested).
I checked big FETS onboard and they're not shorted (As they are not easy to unsolder, I wait for your advices for easyer troubleshoot on other components before I unsolder them for accurate test)
- I assume that, as LCD TVs, there is a feedback using optos, etc... So I cheched what happens on transformers that separate hot from cold side (using a scopemeter). On hot side, nothing happens when I hear relays being on during a second. Obviously, the cold part is not supplied, so there is no feedback wich causes the relay to be off after one second (correct me if I'm wrong).
- I checked what happens on the FETS (gate) with a scopemeter and I think there's nothing significant. Maybe the signal is too low for me to catch him, or maybe there's a problem because FETS should receive something significant on their gates.
- I checked volts on connectors. Nothing on 12V and more connectors. I assume that this is "normal" because the cold part is not powered. only Vsb is OK on "low voltage" connectors. Other voltages are unsignificant (ex : 0.5 v where it should be 5 V).
At this point, I'm stuck ;-). I'm pretty sure that something prevent the first fets to let the power go ahead...
I could unsolder all transistors and ceramic caps to check them all. But it will take ages, and that may cause other problems (bads solders as an example).
So, If anyone has and idea about how to reduce the area to check (I'm pretty sure that the problem is in the hot part).
Is there a way to bypass some electronic controled parts (such as FETS) (with non destructive methods, of course !) to troubleshoot that board...
If anyone has and idea ;-)
Thanks by advance.
PS: I appologize for my poor english (I'm french).Tags: None
by reessiThe tv turned off with a bang. I have found 2 parts blown short on the Y Board:
Q5019 (FGD4536 - 360V, 50A, PDP IGBT)
D5030 (SF10A400HD - ULTRA FAST RECOVERY POWER RECTIFIER)
I have spent a long time trying to find other shorts as when I replace them they blow again.
I bought 5 of each from china so have some spare still.
I see other people replaced these and the tv worked. I see mention of the gate driver having failed but there are no shorts on it or between the pins on it but I guess it could be faulty.
I could... -
by JarzabekPZI have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
by SpudgunHello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
Channel: General Capacitor Questions & Issues
by b-slayerHello.
I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
- first one is to modify le bios to disable the onboard ram.
- second one is to disable the onboard ram by desoldering some components on the mainboard.
so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
so i found that my motherboard... -
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... - Loading...
