Philips 42PF5520D/10 help
  • netdent
    • May 2011
    • 208
    I have this 42 Plasma, it has samsung panel PDP-342SD-YD07
    PSU LJ44-00101CPS
    I replaced a known cap on the psu some time ago which switched the psu on but still no picture, pulled out today to have another go, the y and z boards are humming nicely, at power on you get a brief picture on screen then it dissapears
    I suspect previous owner has been twisting the pots? maybe not, anyway this psu does not show what the voltages should be that I can find, here is what I get
    VE-85v
    VS-190v (this was 207v I turned it down)
    VS scan- minus 175v
    V set- 181v
    If anyone can tell me the correct voltages or recognises the fault please let me know, from what I can see of the picture it looks clear whem on for 1 second
    thanks Ronnie
    sigpic
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 42PF5520D/10 help
    PSU LJ44-00101CPS
    VE-85v
    VS scan- minus 175v
    V set- 181v
    thanks Ronnie
    Usually there is a white label on the panel that shows these voltages. They vary with the individual panel.
    PlainBill
    • netdent
      • May 2011
      • 208
      Hi Plainbill, I removed the psu and found the info on the underside, everything was pretty much right, but when I refitted the psu the alarm led on the psu is blinking a code related to va, seems to relate bottom buffers? not sure why this would happen
      thanks Ronnie
      sigpic
      • PlainBill
        • Feb 2009
        • 7034
        thanks Ronnie
        I'm not sure, either. I'll try to do a little research on this later.
        PlainBill
        • netdent
          • May 2011
          • 208
          PlainBill
          Thanks PlainBill, will lay it to the side meantime.
          thanks Ronnie
          sigpic
