Olevia 537-B11 fault
  • netdent
    • May 2011
    • 208
    Looking for some more help with this one now, had it for some time and need to make a decision, previous owner rekons he bricked it during a firmware upgrade, but think it had issues prior to this, anyway only getting a blue standby light on the front, when power is applied in the back get a brief flick of red led lights allover the main board as if its switching on followed by a small static click noise I think coming from the psu, then just one steady led on the power board. I have replaced most of the caps on the secondry checked for shorted diodes and transistors no luck! none of the plugs have any pin markings, as this set came from the states spare boards are not available even if I did know which board was faulty, any help apreciated
    thanks Ronnie
    sigpic
  • netdent
    • May 2011
    • 208
    Re: Olevia 537-B11 fault
    I'm only getting 5volts from the psu to mainboard, as this tv is from the states I was confident I would get some responses on this forum, would be a shame to trash the tv, can anyone help me out?
    thanks Ronnie
    sigpic
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      If something went wrong during a firmware upgrade, this set may be bad. However, there is a covered inverter board on the left hand side of picture #1. Post a pic of this when you get a chance.
      • netdent
        • May 2011
        • 208
        Thanks for the reply Dgtech, removed the cover and took a pic, there is a slave invertor on the other side, I did try powering with them unplugged from the psu, as said as soon as power applied red leds flick on for a second allover the main board.
        thanks Ronnie
        sigpic
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          There is a little white fuse near the main connector on that slave inverter board. Check this with a meter and report back.
          • netdent
            • May 2011
            • 208
            Hi Dgtech, thanks, that's the master invertor, fuse checks out ok, there is power briefly to the board 22v at switch on?
            thanks Ronnie
            sigpic
            • netdent
              • May 2011
              • 208
              Anyone offer any advice on this set? or might have a working main board to sell?
              thanks Ronnie
              sigpic
              • Rictech
                Panasonic SA-MAX770PU SMPSU board fault....
                by Rictech
                Hello everyone. 😀
                As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                There are no devices that have exploded or otherwise show signs...
                08-26-2024, 01:05 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
                ESR meter came to the rescue again today with a PLC I/O card fault
                by sam_sam_sam
                I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                12-18-2023, 08:17 PM
              • Agent24
                What kind of fault causes this image error?
                by Agent24
                I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
                The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
                What's the most likely cause of this problem, does anyone know?...
                09-22-2025, 11:42 PM
              • cazi1001
                Strange fault on Lenovo ThinkPad E14 Gen. 2
                by cazi1001
                I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                03-24-2024, 04:16 AM
