LG Plasma 42P744 vertical lines
  • Paul Kelly
    • Feb 2011
    • 12
    I have a LG 42P744 plasma TV that has developed lines of blue and red running vertically down the screen. These lines are there on the main menus as well as across the picture any one have any pointers as to where too look for the problem
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG Plasma 42P744 vertical lines
    Maybe the problem is inside the TV? Not much help, is it?
    Well, that's about the best I can do with the information you gave. If you had spent a few minutes with a camera, then attached a picture, I could give a more definitive answer.
    This problem is due to either the logic control card, the X buffers, or the plasma panel itself. If the pattern is in a repeating pattern it's most likely the logic control card. If there is no pattern it's the buffers or the panel. Since the buffers are usually bonded to the conductive tape, either of the last two causes is unrepairable.
    Pictures help us help you.
    PlainBill
    • Paul Kelly
      • Feb 2011
      • 12
      Thanks for the reply
      Apologies but I only have a very basic knowledge of these things if its not a simple part replacement I was hoping to get a replacement board or if I can narrow it down have it looked at by a friend who is much better at this stuff
      The pattern on the screen is constant in all inputs although it has flickering pixels within the lines on the screen
      Can you tell me what connections go in / out too the logic control card to help me identify it and I will strip the card out and photograph it back and font properly and post them
      • PlainBill
        • Feb 2009
        • 7034
        The logic control board is behind the main board. The main board is the board with the input connectors.
        PlainBill
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • afex
          Samsung Plasma TV with vertical lines (model PN50B430P2D)
          by afex
          This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
          This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
          I have attached an image of the TV with these bars displaying....
          11-08-2021, 09:23 PM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • visionbluedemon
          Help. Sony kd-65x85dj vertical lines
          by visionbluedemon
          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
          tried blocking LC lines too, but same results
          is it lcd panel issue or tcon board issue?...
          07-25-2025, 04:56 AM
