I have a LG 42P744 plasma TV that has developed lines of blue and red running vertically down the screen. These lines are there on the main menus as well as across the picture any one have any pointers as to where too look for the problem
LG Plasma 42P744 vertical lines
Tags: None
Re: LG Plasma 42P744 vertical lines
Maybe the problem is inside the TV? Not much help, is it?
Well, that's about the best I can do with the information you gave. If you had spent a few minutes with a camera, then attached a picture, I could give a more definitive answer.
This problem is due to either the logic control card, the X buffers, or the plasma panel itself. If the pattern is in a repeating pattern it's most likely the logic control card. If there is no pattern it's the buffers or the panel. Since the buffers are usually bonded to the conductive tape, either of the last two causes is unrepairable.
Pictures help us help you.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Thanks for the reply
Apologies but I only have a very basic knowledge of these things if its not a simple part replacement I was hoping to get a replacement board or if I can narrow it down have it looked at by a friend who is much better at this stuff
The pattern on the screen is constant in all inputs although it has flickering pixels within the lines on the screen
Can you tell me what connections go in / out too the logic control card to help me identify it and I will strip the card out and photograph it back and font properly and post themComment
The logic control board is behind the main board. The main board is the board with the input connectors.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by pniHi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
by afexThis is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
I have attached an image of the TV with these bars displaying.... -
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos -
First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
tried blocking LC lines too, but same results
is it lcd panel issue or tcon board issue?... - Loading...
