Need help identifying capacitor value on the Samsung LCD TV inverter.
  • newbie1
    • Apr 2010
    • 269
    I saw on the telly that there are 'deadly storms' in the US. Hope you guys there are fine.
    Back to the topic.
    Inverter Model : auo 19.26006.108 found in Samsung LCD TV
    Fault : Plugged. Pressed the Power switch on the TV. Power LED is red. Blinks 4 times. Goes to STEADY red. Then the TV goes 2-sec to black. Sound can be heard. Backlight is off.
    What I did : Measured the output voltage to the inverter. I got 24V. As the power supply board is IDENTICAL with the just repaired & verified working LA32S81B, i swapped them & confirmed that the Power board is not the cause of the TV's 2-sec to black. So now, i am zooming in on either the CCFL or inverter. Unplugged & measure the 5 fuses & found F5 open. I continued further to measure on the surrounding Caps & found C7 having resistance of 118ohms both ways (shorted, rite?).
    So now the questions are :
    1) How do I identify the value of the SMD capacitor C7? Or does anyone have the same inverter schematic which can identify it for me?
    2) IF i could not find an exact SMD capacitor type, can i substitute it with a another capacitor type of the SAME value?
    3) Same goes for the fuse. Am I able to replace it with a glass T3.15A 250V fuse?
    Please note that I DO NOT have a capacitance meter to measure the IDENTICAL SIZE capacitors on the inverter and my soldering skills are not expertly enough to remove the SMD components WITHOUT damaging them..
    Appreciate all your inputs
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Need help identifying capacitor value on the Samsung LCD TV inverter.
    That cap might have a resistor in parallel. 118 ohms is too high to be a short. If the fuse popped then check any transistors after it for shorts before you replace it.
    A working TV? How boring!
    • alexanna
      • Mar 2010
      • 1346
      From firsthand experience I would not use the glass fuse,If there is a short it may not open up fast enough.
      I wonder if the light bulb would be a better substitute for testing?
      • jetadm123
        • 2169
        I'm inclined to agree with Th3_uN1Qu3 that it's likely one of the mosfets, Q4 or Q8, has shorted causing F5 to blow. If you don't feel comfortable unsoldering F5, then you can probably solder the new fuse on top of the old one. Or, with a little practice, if you can handle a soldering iron in each hand, then you can heat up both ends of the fuse at the same time in order to remove it.
        • newbie1
          • Apr 2010
          • 269
          You guys are awesome!!..
          I manage to SLOWLY remove the cap without damaging it. Re-measure across the solder pads on the PCB & it still measures 118ohms. So i replaced Q4 (FDD5614P) (took a long while to be delivered, actually), & replaced the fuse with a 3A picofuse. Switch on the TV & its ALIVE!!!.. let's see whether it can withstand my kids 17hours-non-stop-watching-TV routine.. hehe
          Big thanks to Th3_uN1Qu3, jetadm123 & Alexanna for your inputs..
          • alexanna
            • Mar 2010
            • 1346
            Hell my TVs stay on 24/7 my dogs like watching animal planet
              09-07-2024, 05:50 AM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • NuclearSpartan
              Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
              by NuclearSpartan
              I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
              The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
              I don't see any other visible damage anywhere else on the board....
              11-14-2024, 02:32 PM
              09-06-2024, 11:40 PM
