I have a 5 year old 50 samsung plasma model? The display has alot of yellow and green fuzz it gets better as it warms up and the picture quality does not seem to be as good as it should. Ive tried blowing all the dirt out of the back. Anyhelp would be greatly appreciated
Samsung 50 inch plasma
Re: Samsung 50 inch plasma
Probably the Y buffers.I have a 5 year old 50 samsung plasma model? The display has alot of yellow and green fuzz it gets better as it warms up and the picture quality does not seem to be as good as it should. Ive tried blowing all the dirt out of the back. Anyhelp would be greatly appreciated
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
We need a model number to help you.
A picture of the plasma tv with the back removed helps alot and the front with video.
caution! high voltage around buffers and other boards also can zap you.
Buffer failure on these are common as well as failed capaciters.
search your model number here under old threads.
This info should get you started in the right direction.Comment
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
by porfyriadhsHello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
Thanks a lot !! -
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... -
by CDNBrewerHello, I have a Samsung Plasma TV - Model # PN43D450A2D
This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button... -
by alltvrepairsHi,
I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
Any one met this problem in the past?...10-08-2025, 07:34 AM - Loading...
