Samsung LNT4669F
  • johnsona0
    • Mar 2011
    Samsung LNT4669F
    Not to torture myself or anything but I just bought a new LCD TV a couple months months ago to replace a Samsung LNT4669F that had gone wonky. What had happened was that suddenly the TV had started displaying horizontal flicker lines, through out the screen.
    Not knowing about this great site at that time I called a repairman who diagnosed it as a problem with the Tcon and quoted me $700 to fix it, I discarded it and bought a new tv for $1200
    Now I wonder if it could have been bad caps and I could have fixed it myself...
    could flickering lines (and some bad color) throughout the screen indicate bad caps?
  • daimoku
    • Feb 2011
    • 85
    Re: Samsung LNT4669F
    You can do a visual inspection for busted/swollen caps, but that's not going to find all bad caps. Be sure to use low ESR caps if you find any that need replaced. There's an FAQ on this.
    However, it does sound more like a tcon problem. Looks like you may be able to order one for under $100. Get the part number off the board then look around for an exact match.
    • daimoku
      • Feb 2011
      • 85
      Also, does it exhibit these symptoms on all inputs?
        09-07-2024, 05:50 AM
      • Rubenlily
        Samsung QE50Q67TAU - horizontal lines
        by Rubenlily
        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
        I'm no expert but I've done the tape...
        08-16-2023, 01:12 PM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
        09-06-2024, 11:40 PM
