Samsung LN-S4692D Left Side Blur
  • tlm387
    • Mar 2011
    • 26
    Hey all
    I've got another 46 inch puzzle here. This one is a Samsung LN-S4692D. I was told that "when you turn it on no picture is visible. The sound is there and you can cycle through the channels but can't see anything".
    However when I got it home it had a picture However it's not perfect, the left side of the screen is darker with a red hue, and has a lag or blur effect. The images seems to stay on the screen longer than they should. Occasionally there a vertical lines on the far right side of the screen, they tend to appear only if there is a ticker bar running along the bottom of the screen. This issue occurs on all of the inputs.
    There also appears to be a faint horizontal line running across the middle of the screen.
    I took a video of what the TV is doing. You can see it here.
    I tested the t-con and it is getting about 5v from the LVDS cable.
    Is this typical of a bad t-con or a bad display? Any particular test I can do to determine what the issue is before I spend money on parts for this set?
  • tlm387
    • Mar 2011
    • 26
    Re: Samsung LN-S4692D Left Side Blur
    Whoops my mistake, the problem actually occurs on the right side of the screen
    • tlm387
      • Mar 2011
      • 26
      I pulled the tv all the way apart today and exposed the tab bonds. I tried the trick of applying pressure to the tab bonds, but was unable to get the picture to change at all. I imagine that because the image did not change than all the tab bonds are ok.
      I think I am going to source a replacement t-con for this tv first.
      • daimoku
        • Feb 2011
        • 85
        Any luck with the tcon? It's a fairly common problem on this model.
        • cmoswizard
          OK, I have "fixed" two Samsung panels with this problem. It is due to a driver I.C. debonding from the flextape that feeds into the panel glass.
          The I.C. is located under the metal frame around the panel. If you are desperate enough and brave enough to risk the panel then you have to remove it from the plastic frame and lay it on its back to remove the screws in the metal frame and lift it off.
          On the two units I repaired the problem was in the upper right corner of the screen so it was the furthest right flextape along the top edge of the screen.
          There is virtually nothing you can do to re-bond the chip to the flextape but if you take a piece of heat sink foam about .075" thick and place it over the flextape so that the frame compresses the flextape against the chip then it will usually make contact again. One of my panels was a 100% repair and the other had a slight problem remaining on startup which went away on warmup and was mechanically sensitive. YMMV.
          That is the real signature of this failure mode. Mechanically sensitive and better after warmup as well as the blurring and high persistence in the image.
          Hope this helps, and remember, if you break the glass you'll let all the magic out.
          • valvashon
            Samsung UN60JU6500, stripe on left side of screen
            by valvashon
            Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
            Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
            Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
            Thanks, Val
            11-21-2025, 03:01 PM
            09-07-2024, 05:50 AM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
          • Stephen
            A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
            by Stephen
            Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
            05-29-2025, 10:35 AM
            09-06-2024, 11:40 PM
