Panasonic TX-42PX25 Plasma
  • mckoloum
    • Feb 2011
    Hi there,
    i have a Plasma Panasonic from 2004.
    The other day it just stop working while i was watching,
    and then the 11 blinking red led!!!
    Online i found it could be a fan problem,
    but after downloading the PDF and the troubleshooting from Panasonic,
    they don't talk about 11 times blinking, they say 12 times and it is a tuner problem??
    So i open it and didn't see anything obvious, execpt a capacitor
    on the power board name "P", the top of one big capacitors (1500uF) is little be round!!!
    So my question is: do you think the problem could come from this capacitor, i looked online and found some for approximatly $26.
    Thank you all for your advice.
  • Wizard
    • Mar 2008
    • 2296
    Re: Panasonic TX-42PX25 Plasma
    Not... panasonic is very cagey with data, and troubleshooting is much difficult with panasonic's design due to multiple fault detectors.
    11 blinks is usually power issues. Check all fuses, check voltages etc. In one panasonic, I ended up replacing whole power supply to work, expensive.
    Cheers, Wizard
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      I happened several times, in the search for help from the web, to consult this very interesting forum.
      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
      Having said that I come to the gist of my post on the forum as the title suggests.
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • Lintesir
      Panasonic P42S30 Plasma - Pink sparkles
      by Lintesir
      My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
      There is about a 5cm high region at the top without any sparkles,...
      07-26-2024, 03:16 AM
