LG MU-42PM12X Issues
  • Hacksword
    • Jan 2011
    Hi all, first I would like to say... NICE FORUM! Was just trolling the interwebs and stumbled on this. I am working on an LG set as the title suggests. Basically, I have 6 of these identical sets that are all doing the same thing. The set starts up fine, however after about 30 seconds, you notice that there are lines throughout the picture, horizontal lines that flash and flicker and move all about the screen. I decided to dissect one of the sets since I have so many of them and see whats going on. I have adjusted the Va and Vs pots slightly, and the Va pot made the sparkle in the lines a lot less noticeable. However when I adjusted the Vs pot, just a tiny bit mind you... The set went into standby mode and will not come out. I get the red light on the mainboard and the red light on the outside of the set, but that is it. Any suggestions, I just want to play around with these, but I also dont want to brick another if that is what I did here.
    Thanks in advance for any advise.
    -Hacksword
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LG MU-42PM12X Issues
    Originally posted by Hacksword
    Any suggestions,
    Look for a service manual at
    http://elektrotanya.com/
    --- begin sig file ---
    --- end sig file ---
    • Hacksword
      • Jan 2011
      Thanks, I just got the manual, I will begin troubleshooting
      • jeffrey.r.jones
        • Jul 2012
        Did you ever get anywhere with these? I just picked one up. Has blotchy picture. Going to check voltages first and go from there but would love some help. No lines or anything. Some sparkles and blotchy on faces and action scenes.
          Above, possibly Z-sustain.
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • jeyoung12
            Samsung QN50Q60t lines on screen
            by jeyoung12
            Hi all
            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
            So....i don't know what end of the C ribbon to work with...
            02-26-2024, 10:38 AM
          • DrvLikHell
            Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
            by DrvLikHell
            Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
            The...
            02-05-2025, 01:44 AM
          • pni
            LG 49uf695v vertical coloured lines
            by pni
            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
            11-14-2025, 03:15 AM
