Philips 42PF5331/10 Plasma stuck looping test pattern
  • Chodax
    • Jan 2011
    Hello all, first post and sorry if am posting a question that has already been answered but search turned up nothing. Basically my mother has the above plasma TV and it has worked fine for 3 years or so but a couple of days ago she turned it on and it started cycling through red green blue screens, then a crosshatch screen and finally a test card screen. The screen itself seems fine, the red green blue screens are solid with no errors and good strong colour, crosshatch is a bit messed up with a bit of flickering but the test card is spot on as well.
    Not knowing much about plasma technology I am at a bit of a loss but the screen itself seems fine so I am suspecting a dodgy controller board of some kind but have no idea where to begin. Haven't fixed a plama before but I have done some board level mods on old PC motherboards many moons ago so I am willing to have a dabble (taking full precautions of course), just need some advice and pointing in the right direction if possible.
    Many thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Philips 42PF5331/10 Plasma stuck looping test pattern
    http://elektrotanya.com/
    has service manuals for many TVs. Try looking there first.
    --- begin sig file ---
    --- end sig file ---
    • Chodax
      • Jan 2011
      Ok thanks bud, grabbed a service manual and will try all the obvious stuff like service mode and reseating all connectors first.
      • PlainBill
        • Feb 2009
        • 7034
        Quick and easy test. Pull the LVDS cable that links the Small Signal Board (the one with all the inputs) to the Main Control Board (behind the SSB). The Misc Main Board often has a test mode that will do what you are seeing. It could also be a test mode on the main board, but usually they exit test mode if power is turned off.
        PlainBill
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
        • celiabrown
          Issue with Plasma Philips 37inch chassis FTL2.1
          by celiabrown
          Hello guys,
          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
          Can someone has any symptom like this ?
          Thanks​
          05-09-2024, 10:56 PM
        • Prott
          Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
          by Prott
          Hello fellow Badcappers,
          I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
          I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
          Thank you!
          03-01-2024, 08:23 AM
        • nono34
          Hisense stuck in Colors cycle like test pattern.
          by nono34
          I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
          I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
          10-24-2024, 04:31 PM
        • marker_123
          Philips 50pft4509/12 - stuck on logo
          by marker_123
          Hi.
          Got my TV stuck on logo - looks like eeprom.
          Anyone can help with eeprom dump?
          Board: 715g6165-m02-000-005n
          Model: 50pft4509/12
          Thanks in advance
          Marcin
          10-15-2022, 01:56 PM
