Toshiba 20dl74 inverter problem
  • dobber
    • Jul 2008
    • 83
    I picked up a Toshiba 20dl74 at the local recycling place along with my ususal stuff like laptops and monitors, I figured what the hell 10 bucks. I found that one side of the inverter was bad. It had a bad AO4077 Mosfet Chip on it, So I changed it out and the backlight lit up one time then when back out. So I checked the AO4077 and it burnt again. This is a very had Inverter to get ahold of at a good price so I have to repair it. I believe that the problem is after the Chip do to it lighting up once then burning out again. Is there any known suspect parts that may be causing a ground or overdraw on the chip? or anything that I should checking first? I will post a pic of the inverter as soon as I get home from work so you can see the parts on the board.
    Dobber
  • cadiman
    • Mar 2010
    • 397
    Re: Toshiba 20dl74 inverter problem
    One Inverter transformer shorted? Or is this a single transformer? Is the ao4077 on the power supply or inverter board?
    You could check v and signal with mosfet out. Thats what I always do before replaceing burned ICs (look at spec sheet for that ic) Not sure about this model. There could be a problem with primary v going in (source or load) or secondary v out (source or load) that is taking out your mosfet.
    Not sure if this helps. Good luck!
    • ecking767
      • Oct 2009
      • 492
      Dobber
      I will check surround components like diodes and resistors. There could be a shorted resistor or diode for biasing that MOSFET.
      ecking767
      • dobber
        • Jul 2008
        • 83
        Ok, I will check out the suggestions and post my findings. I have not had time to work on the tv in a week due to having many Laptop repair jobs coming in this last week. I hope to get to in soon, Thanks Guys.
          09-06-2024, 05:27 AM
        • ipn00tic
          Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
          by ipn00tic
          Hello everybody,
          I'm learning alone at home (with you) of course.
          I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
          The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
          I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
          The VCC_GT power...
          03-01-2024, 05:32 AM
          09-06-2024, 05:59 AM
