sony kdl 40v2500 lcd sound but has no picture
    hi hope someone can help i have a sony bravia kdl 40v2500, it swicthes on fine with steady green light and sound is perfect but no picture can hear channel change and volume works fine, you can also c the backlight on, i have changed the t con board and when i first done that and turned it on two white lines came up, turned the tv on and off again and the lines are now gone but still no picture the same as before so now am stuck dont know where to go have checked all wires and cracks and everything seemd fine so i hope someone can help thankyou
    Re: sony kdl 40v2500 lcd sound but has no picture
    Did you every get your sony working? I have the same issue, I've replaced t-con with no results. Although mine never gave me any lines just a completely blank screen.
      White banding on the screen usually means you have a bad LCD panel. If that is the case then you have a bad lcd panel and the tv is only good for parts.
