Vizio VW42LFHDTV10.4 ?
  • chocolate123
    • Dec 2010
    hello,
    One morning my tv had no video ,after paying vizio tech dude to come I got diagnosis that tv inverter boards have bad caps ,on one which I took the cover off you can see oooze coming out of the cap itself.
    The part is marked with tag lg phillipsco lc420wu5(slave) although I suspect master is same board,I believeve bad cap is marked sc43
    bar code reads 8ajzp7811384.
    I am not much of a electronics wizard but know someone who could solder in just the caps or I would replace the boards if it was cheap enough,
    Help me please ,I have been watching my 27 inch tv for weeks now ,any further info needed I would try to provide ,the caps? are blue looking things marked VOA Pet ,Does this make sense can you help me fing caps only ,master and slave boards or make an offer on the screen for parts in northern pa .or thould I just take this out and put about 6 12 ga shotgun shells thru it ,
    I am Bob my handle is chocolate 123 ,am I in the right forum????
  • PlainBill
    • Feb 2009
    • 7034
    Re: Vizio VW42LFHDTV10.4 ?
    Originally posted by chocolate123
    hello,
    No. The NRA hangs out in the 'dumb macho' forums. We prefer 'gents with brains' here.
    Sorry about that. I have a profound lack of respect for those who feel problems are best solved with a shotgun.
    On the chance that was your attempt at humor, the TV is repairable. The least expensive approach would be to order the proper caps and have your friend install them. I believe the full inverter is also available. Google is your friend for that.
    If you want help here, pictures would give us more information. Note the links in my signature for instructions. The description you gave of the caps would indicate the capacity and voltage is on the other side of the cap.
    PlainBill
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
