rca model l37wd12yx1
  • pelota
    • Sep 2010
    • 7
    Re: rca model l37wd12yx1
    I have got the same model TV, with the same symptoms.
    CON3
    Pin.....Actual...."Good"
    1.......~.6........11.9
    2-4.....0..........0
    5-6.....0..........23.39
    7........3.11......3.1
    I checked the opto isolators and found IC3 (P421) to measure about 17 Kohms between pins 3-4 in either direction. IC2 was about 750K. Would this cause no voltage on the 12 and 24 volt lines?
    I read the datasheet for tda16888, and checked the voltages on pins 1,2,9,10,13,19. They all seemed good except for pin 19. It should be somewhere between 80-400 volts. I was getting 5v. Less than 11v shuts the chip off, 11- 14 puts the chip in standby.
    So I replaced the capacitor C27, off of pin9. Now I get -70volts at pin19, but it only lasts 10 seconds or so. Could this be caused by the main filter capacitor?
    Any help much appreciated.
    • ropiemasta
      • Jan 2011
      • 16
      Do you have the service manual for this TV? If so where did you get it.
      • PlainBill
        • Feb 2009
        • 7034
        CON3
        It could be. Are you measuring the voltage properly? You should NEVER get a negative voltage.
        First step: Reread the rest of this thread carefully.
        Second step: Measure the voltage across the main filter cap.
        PlainBill
        • ropiemasta
          • Jan 2011
          • 16
          Made any progress on this??
          • ropiemasta
            • Jan 2011
            • 16
            Just thought of something... Should I always have the standby 5V?
            • PlainBill
              • Feb 2009
              • 7034
              Yes, if you have AC voltage applied to the power supply.
              PlainBill
              • ropiemasta
                • Jan 2011
                • 16
                #27
                Thanks. So correct me if I'm wrong in my thinking... (I've only had bout an hour and a half of sleep) When the tv is turned on, Power goes from the SMPS 1W board to the scaler board. From there it sends the on/off "signal" to the SMPS board to get the 24/12V going. Is my thinking correct? I'm looking at the Interconnect pdf that was previously attached. Thanks for the help.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Exactly right.
                  PlainBill
                  • dhack61
                    • Aug 2010
                    • 33
                    #29
                    I have the same problem Red standby light on. Measured 3.6V on standby voltage from bp600 smps 1w board to scaler board. Anyone have the schemaitcs on the SMPS 1W board or can tell me what generates the 5v standby voltage?
                    Dhack
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Dhack
                      It's discussed above and in other threads. The SMPS board contains two power supplies. The first is the standby supply and is always on. This powers the standby processor (on the main board). When the power button on the remote or the control panel is pressed the standby processor pulls the PS_ON signal high, which turns on the main power supply portion of the SMPS board.
                      Initial troubleshooting is easy. Check for output (typically 5V) from the standby connector. If present, see if the PS_ON signal goes high. If PS_ON goes high, check the outputs of the main supply.
                      PlainBill
                      • dhack61
                        • Aug 2010
                        • 33
                        #31
                        Thanks Bill
                        understand what you are saying but this set ( I think) has its own standby SMPS. Its the board in the upper right hand corner of the Pics of the entire back of the set. It is SMPS W1 and from what I can tell, its only putting out 3.6V to the Scaler board. Cant find this board anywere in stock so Guess I'm gonna have to fix it.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Thanks Bill
                          I have never seen a TV designed that way. The main power supply definitely has two sections; usually these are standby and main.
                          PlainBill
                          • dhack61
                            • Aug 2010
                            • 33
                            #33
                            OK
                            Then what the purpose of the SMPS W1. CON2 on the main SMPS isnt used on this set and if I am reading the SMPS(1).pdf correctly that would be the 5V stand bye, if it was used. So I'm really confused now.
                            Anybody know where to get a cheap service manual?
                            Dhack
                            • hd77shovel
                              • Nov 2010
                              #34
                              What is the "common problem" that causes the red light to stay on?
                              • edugimeno
                                Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                by edugimeno
                                Hi!!
                                Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                At a certain point, moving stuff around, I put all wires back in place and...
                                03-24-2024, 02:31 PM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • piernov
                                Beginner's guidelines
                                by piernov
                                You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
                                There are 2 situations:
                                1. You just want your laptop fixed
                                2. You want to learn about fixing laptops
                                Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
                                Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
                                If you are in situation number 2, then please continue and...
                                09-20-2020, 09:46 AM
